Big Box Store Tubs May Be All Some People Can Afford
Saskman
Not to bring Roger in this but im sure he has seen frozen tubs that the pumps and piping havent burst. I may be wrong.
Yes I have seen pumps, heaters and all kinds of things frozen without breaking. especialy in an open ended non pressure system as a hot tub. But........I have seen more broken things from being frozen than unbroken. I won't use the very stupid saying that Jim uses "duhhh it has to do with the laws of physics" I think he thinks that makes him sound smarter, I guess. But a metal pipe sealed on both ends will burst if it freezes if there is no room for expansion, but if you drill a hole in the same metal pipe it may not break if it can let out enough of it's expansion. Theres alot more factors involved than just Jim saying......"its the laws of physics"
Most of the time a pump head has enough water sitting in it to crack the housing if it freezes solid. Past that PVC will generaly give enough to cover expansion, but not always. The longer you leave it the more things that will break.......
BUT WHATS THE POINT as when it is 10-20 below you would not treat any tub differently as far as protecting it from freezing, as a matter of fact at any temp below freezing you would not treat any tub differently. You want to protect from freezing and facilitate the repair as soon as possible.
This hot tub challange sponsored by [Jim] is the stupidest thing I have ever heard!!
  • Replies 179
  • Created
  • Last Reply
Top Posters In This Topic
There is nothing in this world that can contain the expansion of water, not even diamonds, steel, or titananium. It is "something about the laws of physics."
As with most absolute statements, this is wrong. That would suggest that ice has no compressibility which is absolutely wrong. It is true that most pipes and other things cannot handle the pressure. However, this issue gets complicated very quickly due to the fact that water can form different crystalline structures (called phases) under different pressure and temperature conditions.
Here is link that discusses more about the properties of water than you probably care to know:
http://www.lsbu.ac.uk/water/
.... It is the laws of physics.
You have shown yourself, time and time again to have a very weak and grasping understanding of the laws of physics, Jim.
Lets start with Infinite R, shall we? You can't promote you product on a complete bastardazation and screwed up premise as that B.S and then come here and expect to spout about physics.
Its not the laws of physics since I have seen many a tub In my 10 years and im pretty sure others have, to where the tub was frozen and nothing blew a part. Why dont ice cube trays blow part when frozen why dont ice packs that are thawed and refrozen multiple times blow apart. Are they defying the laws of physics???
It has to do with the fill of the pipe and the pressure of the water as it expands. If there is no relief then it breaks things. Back in the Civil war time they had a bunch of cannon balls siting around with black powder in them. Black powder becomes very unstable as it sits around for a long time. So, to destroy these dangerous balls of black powder, they drilled a hole carefully and filled them with water. Then plugged the hole. Set the ball out side in the winter and it cracked open. These were steel balls. There is nothing in this world that can contain the expansion of water, not even diamonds, steel, or titananium. It is "something about the laws of physics."
I think it would be an interesting test.
I wonder what Tong and Rogers have to say about this? :lol:
What does this all have to do with my Ducky Radio. Are you all saying that if I get water in my duck and it freezes that no duck can withstand the force of expanding water. SOOOO my duck will explode????? See wouldn't this all be easier if the manufacturer just gave me a radio. Now I'm running the risk of exploding duck radio in my tub. Man
Yes. That's exactly right. It has something to do with something called "physics".
That's why there are no real ducks in Colorado. They all exploded last winter. A ducks insualtion factor (D-R) is not infinate. (see Tong and Rogers: Duck Freezing Rates).
I heard Jim has developed a Duck Unfreezing Method (D.U.M) where he blows smoke up it's a$$ to keep it from freezing.
:rolleyes::lol:
There is no known material used in the construction of spas, that can withstand ice without either expanding, distorting bending, or breaking. There has to be a place for the expansion to take place.
In August when the lakes freeze up again for the year I will take my dog team down to Estevan to gey my tub. The train stops there (snow not to thick up there). I hope my pipes don't freeze....it will take me two days to get it home. Wish me luck
These two statements are quite different.
I spoke to a guy in Moose Jaw (near to where I live but a little north of dog river) He says that I get the real Northern Lights so why would I want LEDs. Good point but I still want a radio. The duck only has 5 watts and is mono. Will I void my warranty by putting in one myself. I could even post it on youtube in case the manufacturers want to do the same.
Post hangover corrections I would imagine
:ph34r: srg
Doncha just love that D.U.M. comment a few thousand posts ago? :lol:
Hey fin? You new to Jim's world? If so....welcome.
Everything Jim says is contradicting.
Like Gym says:
"not it's not
yes it is
no it's not
yes it's not
no it is
yes it's no
it's all in your unnerstanding of injuneering and seance "
so sayeth the Jim
:ph34r::lol: srg
Each duck is mono, sure. That's why you need at least 5 or 7 for true Ducky Digital surround sound. There are tubs designed to swirl the water in such a way that each duck stays perfectly placed for optimal sound. Of course, such tubs are expensive, since their pipes are made from Adamantium, moonbeams, and the distilled essence of the sound of one hand clapping.
I'd like to point out I've lived in snowy Ohio for decades, and never lost power for more than a few hours. So, my decision as to which hot tub to purchase will not depend in any way on which one appears to be Freeze Proof. I have also never had a wooden structure that was eaten by beavers, so I will not need to buy a tub that's Beaver Proof. I have also never had anything busted open by Geraldo Rivera in search of Al Capone's Tomb, so I will not buy a tub that's Geraldo Rivera Proof.
Sask, is the Pilates H20 what your talking about and on P&S.com they are touting it as a $14,999 spa but Costco can sell it for $7,999 Cdn
Pilates H2O XP1 sets itself apart with its ultimate massage seats. You can customize 18 programmable hydrotherapy sequence profiles offering a variety of specific massaging options. Four rows of jets pulsate based on the location, intensity and longevity that you select. Enjoy a moderate repeating massage that starts from your neck and shoulders, working down your back and into your legs, or an intense upper and lower lumbar specific pulsating massage. This type of healing power is not available in any other conventional spa.
Pilates H2O is your source for quality home spa hydrotherapy.
Features:
  • Seats 7 people
  • 92 chrome jets:
  • 32 directional typhoon jets
  • 14 rotational typhoon jets
  • 13 cluster and massage jets
  • 33 dual massage/seat sequencer jets
  • 5-pump system:
  • 2 x 160 GPM pumps
  • 1 x 220 GPM pump
  • 1 x 120 CFM blower
  • 1 x 24-hour 30 GPM circulation pump
  • Sani-clean CD ozone generator
  • 2 massage seats
  • 6 removable massage balls
  • Aromatherapy
  • Dual pop-up waterfall
  • Programmable multi-colour LED spa lighting
  • Programmable stereo/CD player with integrated speaker system
  • Subwoofer
  • Wireless watertight remote control for stereo and all spa functions
  • European filtration 2 x 4.6 sq. m (50 sq. ft.)
  • Power depot (full diagnostics)
  • Full 0.64 cm ( 0.25‑in.) ABS bottom tray
  • Durable 0.96 cm (0.375‑in.) cabinet
  • Multi-layered precision-lock insulation package
  • 24/7 after sales care
  • Included:
  • 12.7 cm (5‑in.) thick tapered cover
  • Startup chemical kit
Specifications:
  • Dimensions (L x W x H):
    2.34 m x 2.34 m x 0.91 m
    (7 ft. 8 in. x 7 ft. 8 in. x 3 ft.)
  • Water capacity: 1325 L (350 USG)
  • Dry weight: 454 kg (1000 lb.)
  • Filled weight: 1776 kg (3916 lb.)
Warranty:
  • 5-year warranty against cracking, blistering, fading or delaminating of the shell surface
  • 2-year warranty for all mechanical and solid-state components
  • 2-year warranty for authorized labour beginning on the date of purchase
  • Warranties for other components: the spa cover, light bulb, light lenses, fuses, headrests, cabinet finish and filters are warranted to be free of defects in workmanship and materials at the time of delivery.
I beleive someone posted on either here or wtbht that they bought one and it wasnt it wall hyped to be. I think gulfcoast makes them.
I used to show this movie of this spa in the showroom to tell the full foam story to spa shoppers. It was pretty clear as a bell that full foam is not a good idea.
The only reason for full foam is to cut manufacturing costs. That is all.
I've seen thermaly closed spas frozen also, about a 50/50 mix here. Must be different in Colorado where it freezes slow.
This topic is now closed to further replies.
