Extension cord
hi, the answer depends on the gauge of the extension cord and the load rating of the tub (watts/amps).  There are online tables to determine if the extension cord can handle the power requirements of the tub.
EDIT: OP added pics afterwards.
I would not buy extension cord. Just buy straight cut wire without plug ends on it.  Wire one end into the pack and the other end I would rewire into the GFCI so that the cord becomes the full length wire from pack to GFCI and plug the GFCI into a dedicated wall plug with sufficient rating breaker to hold the spas total AMP rating. I would cut/buy it to the length needed and nothing more.
FYI... 14 Gauge for 11-13 Amps. 12 Gauge for 14-15 Amps. 10 Gauge for 16-20 Amps.
  • Like 1
I was running a 220v but set up but when I was removing the breaker I noticed there was a hair line crack on the unit , so I searched around for the exact same breaker but couldn’t find this one.
It's always best to hard wire the unit and what was suggested by my northern friend is valid advice. However, I understand that it's not always possible. If this is going to be a temporary situation, buy an extension cord rated for 20A and go with it. If you are going to use this in a permanent configuration, buy the cable, put the GFCI on it and plug it into the dedicated 20A outlet.
  • Like 1
Extension cord plugs are not made to handle a continuous load for extended periods of time like needed to run a hot tub. Hire an electrician and have them run power to where you need/want the tub.
I wouldn't risk an extension cord even if you get a heavy-duty one because your insurance company will look for any reason to deny a claim on your house (It's their job to try and save the company money).  If they see something like an extension cord on a hottub, your insurance claim would most likely automatically be denied.    At a very bare minimum I would advise contacting the insurance company and try to get something in writing that says yes you're fine to run a hot tub on an extension cord or not - don't take their word for it over the phone.
I agree - I wouldn't use an extension cord.  Myself  have a 15 foot above-ground pool, and know many would run an extension cord out to it, maybe even over a lawn area.  I ran a separate 120 VAC circuit (through conduit) with its own GFCI to it.
  • Like 1
  • 2 weeks later...
On 4/20/2023 at 9:24 AM, corvette1985 said:
Thank you very much!
would this breaker work with my box? Instead  of the pictures above GE breaker
What's the make and model of your electrical panel. Usually there is a label with that info on it and also compatible breakers. Post that up.
Seimans makes several styles of panels as well as Square D, C-H, Murray, etc. Depending on the panel, the breakers from other companies may work. I can tell you that certain Seimans breakers work in the Square D Homeline panel but others will not but work in Square D QO panels. Same with Seimans panels.
  • Like 1
Can't tell if that's your main panel or your spa panel pictured.  If it's the main, you can get a Spa Panel complete with the GFCI already installed for about $110 off of Amazon, mount it outside and direct wire to the tub.  Then just get a normal $15 double pole 50A breaker from your local big box to feed it from your main panel.
Alternatively, if that's your spa panel pictured, replace it with a new panel and save yourself $60. I caught the Siemens spa panel on sale last year for $100.  No clue why the GFCI alone is a much higher price, but it's been that way for at least a year.
https://www.amazon.com/Square-Schneider-Electric-HOME250SPA-Homeline/dp/B000BQT1AS?source=ps-sl-shoppingads-lpcontext&ref_=fplfs&smid=ATVPDKIKX0DER&th=1
  • 3 months later...
Hi I’m in need of some advice for my spa pack balboa vs500z . I recently changed my heater and went to hook it back up as a 220v and getting paper to the spa pack , tub checked with a meter. But the top control panel is not illuminating and no activity jets etc to the tub… any advice or trouble shooting is very appreciated
