cranbiz
408 -
Days Won
21
cranbiz last won the day on June 23
cranbiz had the most liked content!
cranbiz's Achievements
Hot Tub Aficionado (4/5)
219
Happy Birthday my friend. Hope you had a good day.
Help...Leisure Bay S3 HotTub Leaking...
cranbiz replied to BigDog4All's topic in Portable Hot Tubs & Spas
Could be a lot of things. It could be the pump seal. Won't matter if the pump is off or on. You do really need to know where it's leaking from and if that means drain, move and refill, that's what you got to do. You could try a stop leak product but those are only temporary and they also can do more harm than good. -
Chinese hot tub won’t heat - no error code
cranbiz replied to Fiona UK's topic in Portable Hot Tubs & Spas
Sounds like a bad relay or something related to it on the main board. Post up pictures of the board, the wiring diagram usually found on the inside cover and of the equipment area. -
Hot tub pump runs for a few seconds then shuts off
cranbiz replied to Avisk8's topic in Portable Hot Tubs & Spas
PLEASE start a new thread instead of bumping a several year old thread that is not related to YOUR spa. In that thread, include the info you provided here AND include pictures of the spa pack, the wiring diagram on the inside cover and of your equipment area. -
Hydropool Serenity Hot Tub dead as a doornail :(
cranbiz replied to buriboi's topic in Portable Hot Tubs & Spas
Sounds like the heater might be bad, of course it could be a bad relay. However, we don't have enough information. Please start your own thread. Post up pictures of the inside of your control box, the wiring diagram on the inside of the cover, the equipment area and a somewhat better explanation of exactly what happens. Do you have a multimeter and do you know how to use one? What's the RCD? Is it some internal protection or is it the GFCI circuit breaker> -
Post up the wiring diagram that should be on the inside of the cover. For some reason, I don't think it's wired right, but I'm not sure. Unplug the heater and the pumps, see if it still trips the breakers. If not, then start plugging things back in one at a time until you find out which one is tripping the breakers. The fact that it's tripping both to me indicated a possible wiring problem as for a Watkins tub, the 30A breaker is for the heater and the 20A is for everything else.
Manuals are more general users manuals than anything else. finding the manual usually won't help you fix the tub. Post up a description of your issues and pictures of the spa pack internals, the wiring diagram usually found on the inside cover and of the equipment in the tub and we should be able to help you.
Yes, it will work.
Calling the resident guru @CanadianSpaTech
Yellowed plastics on old Sundance Spa
cranbiz replied to Krulligo's topic in Portable Hot Tubs & Spas
Can't answer your question but on the ozonator, if you have not replaced it, it's not doing anything. They have a finite life, usually 3 years so while it might make bubbles, you are not treating the water. -
First Time Buyer Looking for Advice (Master Spa Vs. Bullfrog)
cranbiz replied to 66Cuda's topic in Portable Hot Tubs & Spas
What @castletoniasaid. I also prefer Bullfrog to Master Spa for a manufacturer. However, dealer support is as important as picking the right spa. What are the reviews on the Master Spa dealer like? Do they support the dealers claim that they take care of their customers? The shell of the Master is heavier than the Bullfrog and that is usually a plus. Bullfrog has interchangeable Jet Packs, which many Bullfrog owners love. Pick the tub that fit you best, including comfortable seating, features you want and has the best after purchase support. -
Drain valves leak. Some additional details or a picture or 2 so we can see what yours is doing would be a welcome sight.
Please start a new thread. This one is 11 years old. Post up a picture of what you are looking for and also the spa pack for us to assist you,
Power Flo lx sp1580z2 Replacement, please help!
cranbiz replied to Sephz's topic in Portable Hot Tubs & Spas
That's what I gave the OP, an A.O. Smith motor that really came very close to the specs on the original pump motor.
