spatech (the unreal one) Posted June 18, 2006 Report Posted June 18, 2006 Figures!!! ... and he sells Coleman!? Quote
Brulan1 Posted June 19, 2006 Report Posted June 19, 2006 ... and he sells Coleman!? Lets open this debate again, its fun. Quote
grahamtasia Posted June 20, 2006 Report Posted June 20, 2006 Circulating pumps are terrible except on HS spas Why are well made circ pumps joined with customized plumbing, a bad idea for spa's? Quote
Brulan1 Posted June 20, 2006 Report Posted June 20, 2006 Why are well made circ pumps joined with customized plumbing, a bad idea for spa's? If I told you no would you have anything to say and back up your thought why it would be a good idea? Quote
grahamtasia Posted July 25, 2006 Report Posted July 25, 2006 If I told you no would you have anything to say and back up your thought why it would be a good idea? That response really doesn't answer the question tho! Quote
Roger Posted July 26, 2006 Report Posted July 26, 2006 That response really doesn't answer the question tho! It does however tell you alot about Brulan. Quote
JohnD Posted July 27, 2006 Report Posted July 27, 2006 The bottom pick ups on any brand DO NOT filter the water. It bypasses the filter and goes straight into your pump, then your heater, then back into the tub. Your right a bottom pick up that filters is a great idea, kinda defeats the purpose of safety though which is why they are designed into the tub. Correction, Coleman DOES have the bottom pick up plumbed to the filter. When pump #1 is running on low speed the tub draws water from the bottom and skims from the top. John Quote
Roger Posted July 27, 2006 Report Posted July 27, 2006 Correction, Coleman DOES have the bottom pick up plumbed to the filter. When pump #1 is running on low speed the tub draws water from the bottom and skims from the top. John Yes alot of tubs on low speed pump 1 draw through the filter only. But what about high speed and pump 2? Quote
JohnD Posted July 27, 2006 Report Posted July 27, 2006 Yes alot of tubs on low speed pump 1 draw through the filter only. But what about high speed and pump 2? Most tubs do not have the foot well intakes plumbed to the filter housing before the filter, they are plumbed directly to the pump intake side after the filter. Some tubs have a bypass valve, other’s simply have y plumbed in there. Coleman draws water to the filter from the top and through the foot well intakes. The foot well intakes are plumbed to the filter housing, before the filter. On high speed some water is drawn through the bypass because the 75 sq/ft filter has a flow rate of 75 gallons per minute, and on high the pump draws about 120 gallons per minute. Bypassing about 45 gallons a min. Coleman has the plumbing diagram of the filter system on there website under purity. Pump 2 was not mentioned, only "filtering pumps". Most 2nd and 3rd pumps on spas are for jetting and not filtering / water clean up. Quote
Brulan1 Posted July 27, 2006 Report Posted July 27, 2006 Most tubs do not have the foot well intakes plumbed to the filter housing before the filter, they are plumbed directly to the pump intake side after the filter. Some tubs have a bypass valve, other’s simply have y plumbed in there. Coleman draws water to the filter from the top and through the foot well intakes. The foot well intakes are plumbed to the filter housing, before the filter. On high speed some water is drawn through the bypass because the 75 sq/ft filter has a flow rate of 75 gallons per minute, and on high the pump draws about 120 gallons per minute. Bypassing about 45 gallons a min. Coleman has the plumbing diagram of the filter system on there website under purity. Pump 2 was not mentioned, only "filtering pumps". Most 2nd and 3rd pumps on spas are for jetting and not filtering / water clean up. That's correct Quote
JohnD Posted July 27, 2006 Report Posted July 27, 2006 That's correct Brulan1 How's the new M6? Do you have one in your store? We have some on order but they won't be here till late August. Quote
Roger Posted July 27, 2006 Report Posted July 27, 2006 Most tubs do not have the foot well intakes plumbed to the filter housing before the filter, they are plumbed directly to the pump intake side after the filter. Some tubs have a bypass valve, other’s simply have y plumbed in there. Umm wrong. most tubs foot well intakes are plumbed before the filter. Coleman draws water to the filter from the top and through the foot well intakes. The foot well intakes are plumbed to the filter housing, before the filter. On high speed some water is drawn through the bypass because the 75 sq/ft filter has a flow rate of 75 gallons per minute, and on high the pump draws about 120 gallons per minute. Bypassing about 45 gallons a min. Yes....some water is filtered and some isn't....just like a whole bunch of other tubs. Coleman has the plumbing diagram of the filter system on there website under purity. I've seen this marketing. Pump 2 was not mentioned, only "filtering pumps". Most 2nd and 3rd pumps on spas are for jetting and not filtering / water clean up. Yes....I am a repair guy/plumber so this is not usefull information to me. But lets not forget when these pumps are used this water, and anything in it, goes directly through the pump/heater. Quote
JohnD Posted July 28, 2006 Report Posted July 28, 2006 1. Umm wrong. most tubs foot well intakes are plumbed before the filter. 2. Yes....some water is filtered and some isn't....just like a whole bunch of other tubs. 3. I've seen this marketing. 4. Yes....I am a repair guy/plumber so this is not usefull information to me. But lets not forget when these pumps are used this water, and anything in it, goes directly through the pump/heater. 1. Take a look at the diagrams below, right or wrong? 2. More water is turned over in 1 hour in a Coleman then a lot of spas. 3. Take a look at an actual Coleman tub, plumbing will be exactly as shown on their website. 4. Have to disagree with ya here, there is no tub on the market that I am aware of that has any pump other then pump#1 or circ pump if installed, pump water through the heater. We sell Coleman, so... I'm some what familiar with their filtering set up . Also sell D1 and Sundance . Quote
Roger Posted July 28, 2006 Report Posted July 28, 2006 1. Take a look at the diagrams below, right or wrong? 2. More water is turned over in 1 hour in a Coleman then a lot of spas. 3. Take a look at an actual Coleman tub, plumbing will be exactly as shown on their website. 4. Have to disagree with ya here, there is no tub on the market that I am aware of that has any pump other then pump#1 or circ pump if installed, pump water through the heater. We sell Coleman, so... I'm some what familiar with their filtering set up . Also sell D1 and Sundance . The only thing missing is whats inside that Tee on the first picture. Most bypass style tubs have a closed loop during filtration that does not alow any water to come from the footwell suction during filtration. This is acomplished by what we in the plumbing industry call a backflow preventer, it's a spring loaded flap that closes the footwell pickup line during low speed filtration. Coleman puts theres in the bottom of there filter canister, same difference. I've seen them and had them apart so the diagram is more for people who don't have a very high understanding of plumbing. What exactly are we dissagreeing about? I guess I kinda thought we were agreeing. I'm not tied to any brand but service them all. I do have a relationship with a D1 guy though. Quote
Guzz Posted July 28, 2006 Report Posted July 28, 2006 You step out of the office for a couple months, see what happens, your still talking about the same subject! Quote
DIYTech Posted July 28, 2006 Report Posted July 28, 2006 I know this is probably a simple question with an even simpler answer, but what does the 'ozoning' do for the spa or water? Quote
Roger Posted July 29, 2006 Report Posted July 29, 2006 I know this is probably a simple question with an even simpler answer, but what does the 'ozoning' do for the spa or water? Ozone or O3 gas is proven to kill bacteria in a spa it is injected into the water as very small bubbles and used to help sanitize. It's effectivness is questioned as there is no real way to measure it or it's effectiveness in a hot tub environment. But along with a silver ion catridge system (which does the same thing, silver ions kill bacteria) Ozone will work good to back up your primary sanitizer (chlorine, bromine) Between additions of primary sanitizer your ozone and silver will do a good job keeping your water bacteria free. But after useing your tub you must use a primary sanitizer because we add way to much "gunk" for ozone and silver ions to kill. Maybe someone on here can tell you the technical definition for "gunk" Quote
spatech (the unreal one) Posted July 31, 2006 Report Posted July 31, 2006 Maybe someone on here can tell you the technical definition for "gunk" It comes from the latin term "Gunkitus, Maximus". Quote
grahamtasia Posted August 21, 2006 Report Posted August 21, 2006 Using a corona discharge ozinator combined with a silver ion works very well together to create a low chlorine system that is extremely easy to maintain. Quote
