Mack25 Posted January 29, 2022 Report Share Posted January 29, 2022 This is a 3 year old Caldera Spa Vancanza model. Noticed dropping water level. Once panel was opened, an open ended vinyl tube was dripping. Seems to happen when heating up. The tube runs on left side and disappears into sealed area I can’t get into with lifting entire hot tub. I’m going to plug it but any thoughts on the cause? Thanks in advance. Video below. IMG_6956.MOV IMG_6957.MOV Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted January 29, 2022 Report Share Posted January 29, 2022 Can't see video Quote Link to comment Share on other sites More sharing options...
Mack25 Posted January 29, 2022 Author Report Share Posted January 29, 2022 Sorry, couldn't get it loaded from iphone but below is youtube link https://youtu.be/nNXTMh6nuy4 Quote Link to comment Share on other sites More sharing options...
Cusser Posted January 30, 2022 Report Share Posted January 30, 2022 On 1/29/2022 at 8:04 AM, Mack25 said: Sorry, couldn't get it loaded from iphone but below is youtube link https://youtu.be/nNXTMh6nuy4 That's a big leak !!! Quote Link to comment Share on other sites More sharing options...
ratchett Posted January 30, 2022 Report Share Posted January 30, 2022 Three year old Caldera? Is it still under warranty? Call the dealer and see if they'll come take a look. Quote Link to comment Share on other sites More sharing options...
Mack25 Posted January 30, 2022 Author Report Share Posted January 30, 2022 I plugged the open ended vinyl tube and no leak. All jets work fine with it plugged. Still can't figure out what this open tube comes from. There is another one with green end on other side as well. Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted January 31, 2022 Report Share Posted January 31, 2022 Intake for the air control valves would be my guess. These may leak from high water level when pumps are off, and from backpressure due to closed, broken, or scaled jets when pumps are on. How many air control valves does it have? 1 Quote Link to comment Share on other sites More sharing options...
castletonia Posted January 31, 2022 Report Share Posted January 31, 2022 Vacanza collection has a 2 year warranty. Guessing that is going to an air control valve. Somewhere there should be a check valve that I'm guessing has failed. Quote Link to comment Share on other sites More sharing options...
Mack25 Posted February 2, 2022 Author Report Share Posted February 2, 2022 On 1/31/2022 at 10:48 AM, RDspaguy said: Intake for the air control valves would be my guess. These may leak from high water level when pumps are off, and from backpressure due to closed, broken, or scaled jets when pumps are on. How many air control valves does it have? There are 4 air control valves. I don’t think it’s from high water levels given water level dropped pretty low and it was still leaking Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted February 3, 2022 Report Share Posted February 3, 2022 Yeah, the air control, once leaking, will create a siphon and drain it down until a jet on that line is exposed to air, or the water level reaches the same height as the open tube, which kills the siphon. 1 Quote Link to comment Share on other sites More sharing options...
GwenLeBlanc Posted November 26, 2022 Report Share Posted November 26, 2022 I have the exact same problem, same make and model, too — the tub is even the same age. Mine was definitely caused by high water levels. Our New England weather has made the cover leak at the center seam and rain water gets in and raises the spa water level. Little did I know it would cause such a problem or replacing the cover would have been much higher on my priorities list! I was curious as to how the OP resolved the issue. I did the same thing (elevated the air hose to keep water from leaking out) and have ordered some new air controls, but will replacing them help? (If I can keep excess water out, of course?) 1 Quote Link to comment Share on other sites More sharing options...
