FromFargo Posted August 26, 2021 Report Share Posted August 26, 2021 Hello - new spa owner, but have had pools throughout my life. Quick backstory - our new neighbors didn't want the Coast / Northwind spa that came with their house, and offered it up for free. A family member works at a spa dealership and provided the spa dolly to wheel it over. Getting it wired next week! For the price, it was impossible to say no 😂 While cleaning it out, noticed cracks on two clear jet surrounds, which screw into the housing and retain a nozzle. Contacted Coast spas, who provided the attached diagram (affected jets circled) but stated that the two jets are not sold and offered replacement parts. Does the community have any insight as to if I can get these replacement surrounds from another source? I'm also considering plastic cement / JB weld to fix these as replacing the jet / body/ diverter is a very in-depth job. Thanks in advance! - Nate NorthWind_Elite_Radiance_Lounger_47_2008 (1).pdf Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted August 27, 2021 Report Share Posted August 27, 2021 I don't know, I've never tried to not replace a cracked thru-wall flange. I don't expect great results, but caulk is a better choice. Get epoxy on those threads and you'll be sorry. 1 Quote Link to comment Share on other sites More sharing options...
FromFargo Posted August 29, 2021 Author Report Share Posted August 29, 2021 On 8/26/2021 at 8:26 PM, RDspaguy said: I don't know, I've never tried to not replace a cracked thru-wall flange. I don't expect great results, but caulk is a better choice. Get epoxy on those threads and you'll be sorry. Thanks for the reply- the idea was to remove the flange, epoxy, cure, then re-install with silicone / caulk. Don’t want to permanently install this fix!! Upon inspecting the 2nd jet, the plastic is much further deteriorated… I dont think repairing it is an option. Any idea on the price range for replacing? I’ll do some calls tomorrow, but interested to hear what is reasonable in the community. It seems crazy to me that this isn’t an available part… are there no aftermarket sources for a flange like this? thanks again! Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted August 29, 2021 Report Share Posted August 29, 2021 Several jet manfs made clear jets. But clear plastic is more brittle and prone to breaking than white/gray, so they stopped making what became a warranty problem for them. I don't recognize the brand so couldn't say if there is a white replacement out there. Since replacing it requires getting to the plumbing from the other side I couldn't say. Depends on how accessible it is under there. Quote Link to comment Share on other sites More sharing options...
FromFargo Posted September 6, 2021 Author Report Share Posted September 6, 2021 Just bumping this to see if anyone has additional insight- I believe it’s a waterway jet but could be mistaken. It is a very deep jet body- I’m a newbie and not sure what to call it. Just looking for the tub-side retaining flange, has anyone had the same issue? Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted September 6, 2021 Report Share Posted September 6, 2021 Need to see where in the spa these jets are located for context. What size is the hole in the acryllic? Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted September 6, 2021 Report Share Posted September 6, 2021 @FromFargo Here you go...$38.00 USD https://www.hottuboutpost.com/coast-spa-volcano-led-2007-cc2107368/ https://coastdepot.coastspas.com/cc2107368-cc2107368 Page 102.. 2016 Coast Spa Parts Cat. here: http://coastspas.info/download/Coast Spas Parts Catalog 03172016.pdf 1 Quote Link to comment Share on other sites More sharing options...
FromFargo Posted September 6, 2021 Author Report Share Posted September 6, 2021 39 minutes ago, CanadianSpaTech said: @FromFargo Here you go...$38.00 USD https://www.hottuboutpost.com/coast-spa-volcano-led-2007-cc2107368/ https://coastdepot.coastspas.com/cc2107368-cc2107368 Page 102.. 2016 Coast Spa Parts Cat. here: http://coastspas.info/download/Coast Spas Parts Catalog 03172016.pdf WOW. Thank you @CanadianSpaTech… absolutely incredible. Ordered 3, 1 as a spare. Confused why their support said the part is discontinued and directed to have it re-plumbed… But that’s water under the bridge (and soon to the inside of my spa!!). One last bonus question as I get prepared to fire it up. I’m assuming that this device is an ozone generator. Would you all recommend replacing this unit, or what is the life expectancy? Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted September 7, 2021 Report Share Posted September 7, 2021 It is an ozonator, and I would replace it in my spa which has 24/7 injection. If it's a timed circulation pump I wouldn't bother. 2 Quote Link to comment Share on other sites More sharing options...
FromFargo Posted September 7, 2021 Author Report Share Posted September 7, 2021 Thanks @RDspaguy - Will see if there is a bulb replacement... might hold off on replacing to see what my O3 levels are at once it's running. Planning on a 3 step bromine process, perhaps an upgrade to a corona discharge would allow lower chemical use (just reading your post on spa water care). Thanks so much for all the help - will post a follow up with it up and running! Quote Link to comment Share on other sites More sharing options...
T MORGAN Posted October 15, 2021 Report Share Posted October 15, 2021 I am looking for the same jet for 6 months now and I am being told that they are back ordered by my vendor hot tub outpost. Also called Coast directly and was told back ordered and will not be available till the end of the year. Anyone that can help me acquire one of these jets i would appreciate it. Cold weather is coming real soon and need to get my spa repaired. Anyone have any luck gluing this clear jet. Jet Part # CC2107368 Quote Link to comment Share on other sites More sharing options...
FromFargo Posted October 16, 2021 Author Report Share Posted October 16, 2021 On 10/15/2021 at 11:48 AM, T MORGAN said: I am looking for the same jet for 6 months now and I am being told that they are back ordered by my vendor hot tub outpost. Also called Coast directly and was told back ordered and will not be available till the end of the year. Anyone that can help me acquire one of these jets i would appreciate it. Cold weather is coming real soon and need to get my spa repaired. Anyone have any luck gluing this clear jet. Jet Part # CC2107368 Same here t Morgan- have not received an update since September, have them on order from both hot tub outpost and coast directly. I have friends who are proficient in 3D printing, tempted to pay to have them design a replacement. Alternatively, is there maybe a general plumbing fitting to simply block off the port? Loosing 2 jets for a while wouldn’t be the end of the world. Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted October 16, 2021 Report Share Posted October 16, 2021 With supply chain issues the older parts are not being made and if they are they are the last to be made. You might have to think out of the box and find a different jet that can fit or be made to fit. Quote Link to comment Share on other sites More sharing options...
T MORGAN Posted October 17, 2021 Report Share Posted October 17, 2021 I am going to contact water ways this week and see if they have anything that wii thread into that jet body 1 Quote Link to comment Share on other sites More sharing options...
FromFargo Posted October 18, 2021 Author Report Share Posted October 18, 2021 T Morgan, please follow back if you hear anything. I will check with my local dealers and see what their suggestions are. thanks! Quote Link to comment Share on other sites More sharing options...
T MORGAN Posted October 18, 2021 Report Share Posted October 18, 2021 Ok I talked to waterway today on the jet. They did have the number CC2107368. As we know that is for the complete jet body with the wall fitting. I assume your jet body is still good like mine and you just need the clear plastic piece that threads into the jet body. It turns out that we can just order components for this jet body. Below are the component parts and numbers that I was supplied. 215-7368 Wall Fitting (Clear Plastic Ring Threaded 711-6500 Gasket for wall fitting 711-7330 Gasket for Jet Body Waterway Plastics will not sell to the public of course that would be to easy. Put a call into Coast to see if they would order them from Waterway Plastics got voice mail and waiting on a call from them. Also working with a company Blue Water spas in Michigan and they are trying to track them down for me. Tim Quote Link to comment Share on other sites More sharing options...
Magcap Posted October 19, 2021 Report Share Posted October 19, 2021 I am in need of this same part, the volcano jet wall fitting. Has anyone been able to find a replacement part? Quote Link to comment Share on other sites More sharing options...
FromFargo Posted October 19, 2021 Author Report Share Posted October 19, 2021 I’ve emailed the parts sales group at Coast with the above information, seeing if they can place an order directly- will report back with information. Quote Link to comment Share on other sites More sharing options...
FromFargo Posted October 25, 2021 Author Report Share Posted October 25, 2021 No response from the sales rep. Just fired another email off. Any word back from your dealership? Quote Link to comment Share on other sites More sharing options...
FromFargo Posted October 26, 2021 Author Report Share Posted October 26, 2021 Quote Link to comment Share on other sites More sharing options...
JimboCh Posted October 26, 2021 Report Share Posted October 26, 2021 https://www.yourpoolhq.com/waterway-215-9891-black-wall-fitting.html https://www.yourpoolhq.com/waterway-2-5-union-gasket-711-6020.html Quote Link to comment Share on other sites More sharing options...
FromFargo Posted October 26, 2021 Author Report Share Posted October 26, 2021 Jimbo the first link in your post looks like too small of a part? Quote Link to comment Share on other sites More sharing options...
FromFargo Posted October 27, 2021 Author Report Share Posted October 27, 2021 The gasket specifies a 3-5/8” ID, so we are looking for a 3-5/8 OD flange. Quote Link to comment Share on other sites More sharing options...
FromFargo Posted November 3, 2021 Author Report Share Posted November 3, 2021 @T MORGAN any update from your dealer? Quote Link to comment Share on other sites More sharing options...
T MORGAN Posted November 7, 2021 Report Share Posted November 7, 2021 Nothing from anyone on my end TIm We need to fine a dealer for waterways that will order these parts for us. Will work on that next week 1 Quote Link to comment Share on other sites More sharing options...
