JimboCh
41 -
JimboCh's Achievements
Spa Savant (3/5)
1
Easy to search online for board repair, here is one. http://www.spa-tek.com/home.html
What trailer to use when moving a hot tub?
JimboCh replied to 6010fd12's topic in Portable Hot Tubs & Spas
I hope you don't end up with a large boat anchor. Good Luck -
broken light lens on Sundance Certa
JimboCh replied to tubblyfub's topic in Portable Hot Tubs & Spas
Corner of hot tub on adjacent concrete?
JimboCh replied to ugotabkdin's topic in Portable Hot Tubs & Spas
So when it rains the water that hits the pool deck is going to run down under the hot tub . Is that how you want it? Usually you make the pad so the water runs off your pad under your hot tub, so not to deteriorate the under side of the tub. -
Coast Spa jet question - please help ID this jet!
JimboCh replied to FromFargo's topic in Portable Hot Tubs & Spas
https://www.yourpoolhq.com/waterway-215-9891-black-wall-fitting.html https://www.yourpoolhq.com/waterway-2-5-union-gasket-711-6020.html -
update: Okay, fired up the hot tub. Did find 2 small leaks not under pressure on the back off the lcd lights cascading water fall.(just constant dripping) surprising how much water can collect with it just dripping. Used silicone, put it on yesterday, waiting until this afternoon to put back the 3 inches of water I had to take out of tub to make the repair. Had to take off the one side panel to get at the lights to make the repair. Lets hope I got the silicone in the right spots to stop the leaks, wasn't exactly that easy to reach in and get to the lights.
Try renting a trailer at your local Tractor Supply. Each store usually has one you can rent by the hour or for the day. They are pretty low to the ground so you won't have to lift it that high. -
Will do, got another question for you. I'm thinking of placing a regular 15 amp breaker in that spa box on side of the house with the 60amp gfci............ I want to run a 3 wire to a GFCI receptacle that I will mount onto the brick pillar that is about 5ft from tub, this receptacle will be facing toward the house, not the hot tub. Will be wired like this, is that okay? and will just the 60amp breaker in my house electric panel be okay or must I get a higher breaker in there to run the 15amp breaker additional to the 60amp? What size underground wire do I need to buy to run off the 15 amp breaker to the 120 GFCI Receptacle? Branch Circuit/GFCI Outlet
Getting close now, just waiting for 60amp GFCI breaker to arrive via UPS tonight. I'm thinking of filling tub with water now. Check out my wiring, let me know if you see any issues. Yeah, Yeah I know the pvc pipe is exactly level, I'm a rookie though lol...did my best. No idea why the first picture is turned. It's not like that on the wall. lol I drilled the hole in the middle of the brick I thought but I think the drill wandered on me a little bit to as why it's not level with hole coming out of box. Had box installed first before drilling hole in wall....and there was no way I was taking it off the wall to redrill 3 more holes for the screws.
venting Does hot tub need side vent for moisture?
JimboCh replied to CanadaBeachHotTub's topic in Portable Hot Tubs & Spas
Don't see that helping much at all, it's a dryer vent and those louvers will only open when there is a force of air opening those louvers, with no forceful air from your hot tub, The louvers will never open.- 5 replies
- vapor barrier
- insulation
Well I don't have 6/3 wire, but it looks like I'm going to have extra 6/2 wire, can I take out a single straight white wire out of that wire and use just for my neutral from house panel to gfci box? I'm only using 3/4" pvc pipe for going through 12" wall(cinderblock and brick) then about 3 ft over to GFCI box. I believe I can fit the 6/2 wire and a single white strand through the pipe and get it where I have to. So in total the run is about 6ft in total counting the wire in the house panel to get to the neutral bar in the GFCI Box? Would that be acceptable? code wise?
