Iowa Posted November 6, 2021 Report Share Posted November 6, 2021 heater is heating, pumps working but hot tub wont heat past 94 at this point , it maintains 94 but wont heat beyond that. Quote Link to comment Share on other sites More sharing options...
cranbiz Posted November 8, 2021 Report Share Posted November 8, 2021 I suspect it's a sensor. Depending on the tub, there might be two sensors . Post up pictures of the spa pack, the wiring diagram usually found on the cover and of the equipment area so we know what you have. 1 Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted November 8, 2021 Report Share Posted November 8, 2021 I suspect that it is only heating on one leg of the heater and you have a bad relay on the other leg. Quote Link to comment Share on other sites More sharing options...
Iowa Posted November 9, 2021 Author Report Share Posted November 9, 2021 Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted November 9, 2021 Report Share Posted November 9, 2021 When hear "only heats to 90something", I assume the heater is not working at all and the pumps are keeping it warm. Do you have a multimeter? Test voltage to heater. Test pressure switch for continuity. Test across thermo-disc for voltage. Post results. Quote Link to comment Share on other sites More sharing options...
Iowa Posted November 9, 2021 Author Report Share Posted November 9, 2021 I cleaned it out , emptied it over the weekend, checked all the plumbing and refilled. temp went from 65 to 86 and stalls at 86, pressure switch is new, and tested . I am little nervous using a multimeter, but will borrow one again tomorrow and check again. Could it be the hi limit switch ? heating element is new, pressure switch is new. Quote Link to comment Share on other sites More sharing options...
Iowa Posted November 9, 2021 Author Report Share Posted November 9, 2021 Oh and does it look like the heater is wired correctly ? Also know that this all started when I emptied it , cleaned it and refilled it in the summer, has not worked right since. So I replaced the heating element and the pressure switch. Had a new shut off box installed, I am about to give up but winter almost here and I have put so much in to it, I hate to give up now. Quote Link to comment Share on other sites More sharing options...
