Hi all, have the same problems with Mspa lite. E1 code from first day of use not heating, ( have not had spa a month), arrived on 29th June new, did everything which it says to do in handbook, still no good, contacted Mspa, waste of time because they say I live in NI,,, told me to contacted who I bought it from, awaiting new upgrade filter unit from them. Not pleased....  at all with workings of spa.
  • Like 1
Share this post
Link to post
Sadly I have the same E1 error code on the spa bought from Lidl last month. I have cleaned all the filters as suggested but the tub simply will not heat. Bubbles will work but as soon as we try to heat the E1 code pops up. We've hardly used the tub (only twice) so I suspect this is a dodgy batch. My problem is that I've lost my receipt so I either need to find a solution or I have wasted my money? Is it worth paying for an expert/technician to come in and fix? Any suggestions?
  • Like 1
Share this post
Link to post
Hi,
I had this same error code - E1. I read all the forums and changed the heat sensor. Filled the spa back up and still had the error code. I simply disconnected the 4 pin connector to the PCU control unit, cleaned it and made a good connection and the error went. Spa now working perfectly!
  • Like 1
Share this post
Link to post
Op 25-7-2020 om 16:09 zei Kim newman:
Ik heb ook de mijne gekocht op 28 juni, hot tub niet verwarmd, vervangen door een nieuw type geleverd door Mspa voor E1-fout, maar nu is het volledig gestopt met verwarmen.
Ik denk dat we een defecte batch hebben verkocht.
Heb je een oplossing gevonden ivm met verwarmen ,hebben net hetzelfde aan de hand ,de onze wil ook niet meer verwarmen nu
Share this post
Link to post
23 hours ago, PhilJ said:
Hi,
We have a winner
Share this post
Link to post
Hi guys, I’ve just gone to put mine on after using it a handful of times low and behold error code . I too bought it in 28th June ( Lidl uk) I’m devastated!
have any of you had any luck at all in getting a replacement or refund?
Share this post
Link to post
