Lay Z Spa E13 error
Crampy
Hi all,
I have a Lay Z Spa Hawaii Hydrojet Pro which has been a superb tub til now.
It's 2 years old and has had no problems so far but has now developed an E13 error code on the pump.
Lay Z Spa website shows this as the cause.
Quote
'Error code for issue where the electrical signal within the pump body between the control panel and power board has become disconnected.'
Just wondering if anybody else has had this fault and managed to fix it as I am out of the warranty period.
Thanks in advance for any help anybody can offer me :)
  • 7 months later...
I have been fixing spas for 25 years and was an electrician for 5 years before that. The quoted description of the problem does not make sense, they use terms that are not standard in the English language. I would surmise from that quote that there is both a control panel and a power board within the pump "body", whatever that is. And that, for some inexplicable reason, it has had a wire come loose.
We see quite a few people on here that revive old unanswered threads about these inflatable tubs. Bottom line is, in my opinion, they are disposable and were never made to be fixed. In many threads, people are unable to find parts for them. Throw it away and buy a new one. Try a real spa, you will not be impressed with your inflatable anymore. Check facebook and craigslist for used or refurbished spas.
Unfortunately, that is the best advice I can give you. Good luck.
