I would appreciate advice on getting started with a used hot tub. I've researched these pages and saved the processes from Nitro's chlorine method, Water Bear's 3-step bromine method and Hillbilly Hot Tub's decontamination method.
I owned a Sundance Optima back in the '90s and used Baqua Spa sanitizer but it looks like that method has never really taken hold but I liked it for its stability. I am buying a 2-1/2 year old Jacuzzi J-365 that the original owner contracted with a local company to maintain for him. It is using bromine.
I believe I want to continue with the bromine principally for less frequent maintenance / high temp stability since we're traveling a lot. I do plan to install new filters and get a Taylor test kit.
1. Would you recommend that I start with a decontamination even though the tub has been professionally maintained?
2. I see that both chlorine and bromine are chosen by very knowledgeable people and there isn't a strong consensus for one over the other. True? I don't see much love for the Frog @Ease system on these pages? Is bromine the best choice assuming I want less frequent maintenance?
Thanks in advance!
Joe
yes. use a pruduct such as Ahhsome.
true
It won't require daily additions of sanitizer once you get everything set up and the floater adjusted but there is often a period of trial and error to get there.
  • Like 1
