Thanks for the reply. Did what you said, it like scrolled through a bunch of negative numbers and then just went back to "hi". But what was the number on the fifth push of the button? It will be a negative number. Tried unplugging the cell cord from control panel and back in. After doing this earlier and just now it goes back to green lights by "power" & "generating" (which got me excited) but then after a minute red light by "high salt". Is there a way to reset or re-calibrate the thing?
Added 2 - 40lb bags over a month ago because it was a little low and the low salt indicator was on (I can't remember the value). That's all we've put in it. When I used a test strip last month before adding it jived with control panel. Now my test strip is saying just under 6000ppm and box just says "hi"...whereas Leslies said 2900. I just don't feel theres ANY way our salt can be this high considering all we've added is 2 bags. We have 28,000 gallons.
The salt could still be too high, even with two bags. Depends where it started at.
NUMBER WAS -6100 (I just went and did it again). It stopped there for a second and then went to "0", then "HI". So, it's saying 6100. My test strips were reading right under 6000.
So, that being said, if it really is that high, can I avoid draining that much water, and how much would I have to drain. What are my options to lower salinity?
