Pouring A Pad On An Uneven Surface
I am going to be pouring a pad for my new hot tub in the next few weeks. The pad size will be 8' wide and a length of 7'. In between the 7' length span, the ground has a swale in it that goes down about 5". Should I put some gravel in the swale to make it even with the rest of the ground or should I just fill in the void with concrete?
I am planning to make the pad 5 1/2" thick with rebar tied together and grounded. If anyone has any thoughts about this let me know.
Thanks.
It don't matter. What would you rather buy? More gravel? Or more concrete? 5 1/2 inches is enough concrete. I would say throw some gravel at it.
Thanks.
Either way would be fine I am sure.....if your depression is 4'x4'x5" you will need an additional .18 yards of concrete....at $120 per yard..you are talking $21.60 additional for the concrete. for a pad that small (8'x7'x5") you are only talking about .64 yards to begin with at 5" thickness. Your delivery charges will be far more than your concrete. I would fill it with concrete and be done....but thats just me.
"Swales" are typically installed to facilitate drainage. I would make sure this is NOT the case and if it is I would recomend putting in a pipe to insure you are not diverting rain (snow melt, ETC.) into and therfore against/around your new pad/spa.
Just my .02
very, very good call...I forgot about that!!! a pipe is good idea for major drainage. If it is just a water runoff thing, I would drop one side of my slab by about 1/4-1/2 inch to facilitate water runoff in the direction I want.
