Anka
Content Count
47 -
0 NeutralAbout Anka
Rank
Junior Member
Contact Methods
http://ellerbach.com/Pool
Gender
Female
Eastern PA
Gender
Female
Method Used To Raise The Ta Level
Anka replied to applebomber's topic in Swimming Pool Water Chemistry
There's not really any need to dissolve sodium bicarb. You can just dump it in dry. Set your pump to recirculate if you have that option. You might have to break up some clumps with a brush—just push them around a little and they'll dissolve. Or dissolve it in a bucket of water and pour it in. Either way, try to broadcast it across the surface; that way it'll get mixed more quickly. That's going to be quite a bit of bicarb—about 10 pounds? I would do this in two steps. Add half the amount, let it mix in for several hours, test. Add more if needed. -
Pollen...vacuuming With A Skimmer Sock On The Basket?
Anka replied to scdigger's topic in All Swimming Pools Types
Yes, it's okay to vacuum with a skimmer sock inside the skimmer basket. Depending on the amount of debris in your pool you may want to check the sock part-way through the vacuuming and change it or clean it so suction is not impeded by its contents. -
First Time Pool Owner, Old Pool--Pls Help
Anka replied to Corsara's topic in All Swimming Pools Types
Not fatal, no. Anything can be fixed. I would urge you to buy a good test kit, either a Taylor K-2006 or a TF-100. A good test kit will save you big chunks of money and time. -
Congratulations on the new house and pool! To give the most effective advice I have some questions for you: 1. Are you able to tell how the water looks right now? 2. What sanitizer do you plan to use, i.e., chlorine (liquid such as household bleach or 10%, pucks, granules) or a Baquacil-type substance? 3. Do you have a test kit? If so, which one? You may wish to do some reading at Pool School which will give you a lot of excellent information. Can't help with the plumbing question, I'm sorry. -
Drained Pool, Need Help On Adding Chlorine
Anka replied to AMG's topic in Swimming Pool Water Chemistry
Excellent question: Where does the CYA go? We don't know. There have been many reports of CYA having disappeared over winter, especially in closed pools. There are some thoughts that it may be consumed by bacteria or algae but no-one seems to know for sure. I end the season with about 60ppm CYA. When I close I bring the FC level to 20 ppm, shut off the pump and disconnect the plumbing. The pool is not covered over winter. By the end of December it's frozen solid and won't be fully thawed until the end of March/first week of April. At that time there is no measurable amount of chlorine or CY -
No. I have a water season which goes from the end of March to the end of December and a swim season from the end of May to the end of September. Between December and March the pool is frozen solid. I test and treat the water from the end of March to the end of November. -
new2me, these folks are in the UK being ripped off by a vendor who deals in the UK. They're not looking to save a 'buck'—they work with pounds sterling, and I'm sure when they initiated the purchase they thought they were working with a reputable dealer. We've all been defrauded at some time or other, it happens even in North America.
I use a 25 ml volumetric pipette for dilution tests, i.e., testing the strength of the liquid chlorine I buy. For daily water testing I use the graduated cylinders which came with my test kit. Once you get the hang of placing the meniscus, or at least place it consistently, the accuracy provided is close enough.
Things we learned in kindergarten: * If it sounds too good to be true, it is. * You get what you pay for. It reads chlorine to "above 3 ppm". What kind of chlorine: free? combined? What is your normal chlorine level now? If mine were to test at 0.2 ppm I would scramble for the bleach bottles. I run my pool at between 3 and 5 ppm and have to be able to test for those levels. This device would not be useful to me. Moreover, electronic testers require frequent calibration. Will they include standardizing solutions? Or do you have to make your own? For 20 bucks? Um . . .
I just recently bought a pint of CYA reagent from amatoind.com. The reagent was $6-something and the shipping was $5-something. Those little refills available through the vendor where I bought my TF-100 kit aren't useful to me. Those of us who utilize a combination of pucks and bleach need to test for CYA more frequently and it makes sense to buy in larger quantities. Amatoind is a good company to work with: Personal e-mails from Mary to keep one informed of order status and the shipping slip comes with a handwritten note from her saying thank-you for the order. Prices are reasonable and the s -
I would get some stabilizer and add 1/2 the amount recommended by the Pool Calculator for your water volume. Since all of your other chems are balanced I would then put the pucks in the chlorinator and let them maintain the chlorine while adding CYA. Do you have enough CYA testing reagent to keep track of the levels? Conversely, you can add the stabilizer now and just go with bleach, and keep the pucks for when you're out of town and not able to maintain the pool. I use mine at the beginning of the season until I have the CYA level I want and then go with just bleach, holding the pucks until -
Oh, come on. Laugh. He works hard to put this forum out there. Indulge him. Her?
That's very hard to estimate because it depends on so many factors: Water temperature—is it steady, i.e., a heated pool which affects the rate of algae growth? Swimmer load? Anticipated maintenance and attention paid to the pool—infrequent pool care will require more chemicals? Type of sanitation system used: Chlorine? Saltwater chlorine generator? Baquacil? Trichlor/dichlor tablets? Type of pool: Vinyl? Fiberglass? Plaster/concrete/other? Environment: Trees? Agricultural dust? Grass clippings? From my own experience with a 13,000 above-ground pool, unheated, used daily by three large d
Hi Michael, Yeah, that was a lot of bleach. According to the Pool Calculator you raised the FC by at least 39 ppm. That'll kill those green buggers, eh? Do you have a test kit? If not, the Taylor K-2006 is excellent, well worth the money, and refills come in a variety of quantities which makes the K-2006 economical in the long run. Another good kit is TF-TestKits which has a slightly lower start-up cost but refills are smaller. A good test kit in combination with the Pool Calculator will take the guess work out of chemical additions and subsequent balancing of the water. Both of these kits
Are Salt Water Generator Systems Worth It ?
Anka replied to southportmom's topic in All Swimming Pools Types
We add salt to our water for the "feel", approximately 1800 ppm. Yes, it does feel silky and smooth. But it's not why I would buy a SWG. To us, adding a cup or two of liquid chlorine each day is no trouble. We're in the pool each day, we test the water each day, we check and empty the skimmer basket each day. Adding chlorine is just part of our five-minutes-a-day pool maintenance routine, it's not a big expense in time or money in any way. We like messing with the pool.
