Rob W Posted August 28, 2007 Report Share Posted August 28, 2007 I'll need to lift the spa about 7 ft onto a deck. The spa is around 800lbs and 7.5ft x 7.5ft. I brought this option up to the spa dealer earlier and he didn't think it would work. I'm trying to find an alternative to using a crane. The crane company came out today and also suggested the possibility of a forklift. Since I have conflicting opinions I'd like to get a few more. Quote Link to comment Share on other sites More sharing options...
Pathfinder Posted August 28, 2007 Report Share Posted August 28, 2007 If you had concrete or pavement in the area that the forklift is going on then it should be no problem but you need to have fork extensions to properly move a spa as the regular forks are too short and would dig into the underside of the spa. If the area is dirt or grass the forklift will end up digging into the ground with the wheels trying to line up then will get stuck. A stuck forklift is not fun to get out. Quote Link to comment Share on other sites More sharing options...
Rob W Posted August 29, 2007 Author Report Share Posted August 29, 2007 If you had concrete or pavement in the area that the forklift is going on then it should be no problem but you need to have fork extensions to properly move a spa as the regular forks are too short and would dig into the underside of the spa. If the area is dirt or grass the forklift will end up digging into the ground with the wheels trying to line up then will get stuck. A stuck forklift is not fun to get out. OK...thanks. The surface right now is basically 'fill' and consists of dirt and rocks so maybe not a good idea. Quote Link to comment Share on other sites More sharing options...
Brulan1 Posted August 29, 2007 Report Share Posted August 29, 2007 If you had concrete or pavement in the area that the forklift is going on then it should be no problem but you need to have fork extensions to properly move a spa as the regular forks are too short and would dig into the underside of the spa. If the area is dirt or grass the forklift will end up digging into the ground with the wheels trying to line up then will get stuck. A stuck forklift is not fun to get out. OK...thanks. The surface right now is basically 'fill' and consists of dirt and rocks so maybe not a good idea. A BOOM should cost around 250 bucks Quote Link to comment Share on other sites More sharing options...
Rob W Posted August 29, 2007 Author Report Share Posted August 29, 2007 Yep...$140 per hr, and a 2 hr minimum = $280. Not that bad when you figure you're spending $8K anyway Quote Link to comment Share on other sites More sharing options...
Roger Posted August 29, 2007 Report Share Posted August 29, 2007 Yep...$140 per hr, and a 2 hr minimum = $280. Not that bad when you figure you're spending $8K anyway Rough terrain forklift and extensions no problem, less expensive than a crane. Done it many times. Quote Link to comment Share on other sites More sharing options...
Brulan1 Posted August 29, 2007 Report Share Posted August 29, 2007 Yep...$140 per hr, and a 2 hr minimum = $280. Not that bad when you figure you're spending $8K anyway Rough terrain forklift and extensions no problem, less expensive than a crane. Done it many times. Some suburban areas have restrictions into yards due to size or may be other obscicles prohibiting further unto the delivery process, Roger. I still havn't witnessed a flying forklift. Quote Link to comment Share on other sites More sharing options...
Roger Posted August 29, 2007 Report Share Posted August 29, 2007 Roger. I still havn't witnessed a flying forklift. I have three of them, and a big old empty slab where a tub should be sitting and no one willing to alow me to do a thorough field test on any of there units. Quote Link to comment Share on other sites More sharing options...
thestallion Posted August 29, 2007 Report Share Posted August 29, 2007 If you can find a lift that is use for sod it has tires that are made for the dirt and will be fine as for the short forks just be smart how you lift with the Epic and its bottom you should be able to make it work. Quote Link to comment Share on other sites More sharing options...
Warlord Posted September 9, 2007 Report Share Posted September 9, 2007 I'll need to lift the spa about 7 ft onto a deck. The spa is around 800lbs and 7.5ft x 7.5ft. I brought this option up to the spa dealer earlier and he didn't think it would work. I'm trying to find an alternative to using a crane. The crane company came out today and also suggested the possibility of a forklift. Since I have conflicting opinions I'd like to get a few more. You must have some obstructions in the way - trees, or electrical wiring, or maybe an unlevel surface????. Or, perhaps your neighbor's home is too close????. I ordered a Crane Co. to move my spa. They lifted the spa COMPLETELY over my house and trees. And my spa is 8-ft x 8-ft. It took them a little over 20-minutes. Quote Link to comment Share on other sites More sharing options...
