Flukeman Posted November 29, 2023 Report Share Posted November 29, 2023 (edited) Actual water temp 91 F. Display rapidly increases to 112 and trips out giving OH code, then HL code a minute later Any ideas? Brand new filters All jets under water, and pumping just replaced pump, and filled Thanks in advance Edited November 29, 2023 by Flukeman More detail Quote Link to comment Share on other sites More sharing options...
waterbear Posted November 29, 2023 Report Share Posted November 29, 2023 Make and model would be a good starting point. Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted November 30, 2023 Report Share Posted November 30, 2023 If it is a Jacuzzi or Sundance Spa post the year of manufacture. There is a recall on Temp sensors. https://www.jacuzzi.com/en-us/recall.html# Jacuzzi or not your issue is likely with the temp sensor. Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted November 30, 2023 Report Share Posted November 30, 2023 Most likely the heater is running without flow or the sensor is touching the element. Remove filter. Check heater pump, which is often a different pump than the jets, for flow. Check to verify power is turning off to the heater as a stuck relay will cause it to do as you describe as soon as power is turned on. Quote Link to comment Share on other sites More sharing options...
Flukeman Posted December 1, 2023 Author Report Share Posted December 1, 2023 The spa is 21 years old. My owners manual does not tell me manufacturer. I thought it was a Sundance back then, but over the years I have replaced parts and the designation used was Gatsby CS6237. I have replaced main box, heater, and topside control panel over the years. I have two jet pumps and a circulation pump off the heater. Yesterday a friend tested voltages on the heater, readings were 236v. Circulation pump is working, tub heats up as it should to set point, then just ticks off degrees to 112 and trips. When I say heats as should I mean slow and steady over time. But once it reaches the set point(102) it just starts ticking off 102 to 112 in seconds. Quote Link to comment Share on other sites More sharing options...
