Hydropool 14FX Electrical Hookup
eac183
You will need two GFCI breakers. Each controller needs to be wired up individually
That means you will need a 100 amp service panel housing the 2 GFCI breakers.
The unit will be heating at an 11 KW. capacity.
Pulling roughly 85 amps wide open.
Well, according to the wiring diagrams provided, the OP does not have to wire in 2 GFCI breakers to run the panels. He can do it with 1 100A circuit and a 100A GFCI. He can also opt not to run the slave heater and run just a 50A circuit. Of course, the swim spa will heat much more slowly than if they use both heaters.
I believe that 2 50A feeds will provide some redundancy as a failure in the slave panel probably won't take the entire system down. While it will cost more to run 2 50A circuits, it won't be much more than running 1 100A circuit.
  • Like 2
