2007 Hot Springs Aria
That's on the high side for that age. I would only offer as high as $3500 IF you can see it fully running (heated to temperature, jets running etc) and look behind the access panel for any leaks while it's running.
I'm a hotspring highlife fanboy, but they are not the most DIY weekend warrior friendly to repair.  If that tub is leaking or not working, it could be expensive to fix
  • Like 1
