Spa temperature dropping
Susanj
I replied to your other post.
On a fully insulated tub on the ground you can go days with no damage, and the first things to freeze will be in the equipment area. On a deck you lose a day or 2. Not full-foam and it can freeze pipes in hours.
Gfci breakers trip for many reasons. Often it is the breaker itself, or loose connections on the breaker. Most things in the spa will trip it repeatedly, but not always. Nuisance tripping is the most difficult issue to troubleshoot in a spa.
  • Like 2
