ryans121 Posted October 1, 2020 Report Share Posted October 1, 2020 The main water valve fitting cracked and I have to replace it. I noticed there are two 1/4" lines going off from the 3/4" tubing. One goes to a drain and one to the jets pump. I can't find this part, and have tried making my own but it leaks. I am wondering if I can cap the 1/4" lines and only put back 3/4" line. Thanks Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted October 1, 2020 Report Share Posted October 1, 2020 Are the 1/4" lines coming off the black part seen through the hole? The black part looks like a mazzi injector for ozone system Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted October 1, 2020 Report Share Posted October 1, 2020 Post a pic of the fitting. Quote Link to comment Share on other sites More sharing options...
ryans121 Posted October 1, 2020 Author Report Share Posted October 1, 2020 5 hours ago, CanadianSpaTech said: Are the 1/4" lines coming off the black part seen through the hole? The black part looks like a mazzi injector for ozone system The 1/4 lines are underneath the equipment compartment. It's not part of the ozone system as I already capped that off 32 minutes ago, RDspaguy said: Post a pic of the fitting. Here is the fitting I'm talking about. I circled it. The pic I showed earlier is underneath that fitting, with insulation removed. There are two 1/4 lines coming off the 3/4 piping underneath. One goes to the drain and the other goes to the main jets pump. You can see the 1/4 bleed line going underneath from the "K" pump Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted October 2, 2020 Report Share Posted October 2, 2020 That's a drawing of the fitting, and does not help me find it for you. Post a pic of the fitting. Quote Link to comment Share on other sites More sharing options...
ryans121 Posted October 2, 2020 Author Report Share Posted October 2, 2020 1 hour ago, RDspaguy said: That's a drawing of the fitting, and does not help me find it for you. Post a pic of the fitting. I don't have a picture unfortunately It was cracked and I sawed it off and threw it out. What the fitting was: 3/4 pvc slip elbow with 1/4" barbs coming off either side. So it's like a 4 way tee but 3/4" slip x 3/4" slip x 1/4" barb x 1/4" barb I attached a visual here... the black lines represent the 1/4 barbs Keep in mind this is underneath the 3/4" barb inside the equipment compartment. The 3/4 barb would attach to this 3/4 pvc elbow Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted October 3, 2020 Report Share Posted October 3, 2020 https://www.diypartcenter.com/products/vita-spa-ozonator-coupler-reducer-3-8-inch-barbed-x-1-4-inch-barbed-vit470207 Drill hole for 3/8" end and Devcon 2 part plastic weld epoxy into hole Quote Link to comment Share on other sites More sharing options...
ryans121 Posted October 3, 2020 Author Report Share Posted October 3, 2020 24 minutes ago, CanadianSpaTech said: https://www.diypartcenter.com/products/vita-spa-ozonator-coupler-reducer-3-8-inch-barbed-x-1-4-inch-barbed-vit470207 Drill hole for 3/8" end and Devcon 2 part plastic weld epoxy into hole I did try that with these https://www.backyardplus.com/proddetail.php?prod=30598 and used regular pvc cement as instructed but my vinyl tubes were too tight and they became lose and leaked... I was going to use this and connect the 1/4 to the pump and just cap the drain bleedline Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted October 3, 2020 Report Share Posted October 3, 2020 8 hours ago, ryans121 said: used regular pvc cement Use a 2 part epoxy like Devcon plastic weld or Devcon 5 minute epoxy and it will outlast the dinosaurs. You can also use it to plug the open end. 1 Quote Link to comment Share on other sites More sharing options...
ryans121 Posted October 4, 2020 Author Report Share Posted October 4, 2020 16 hours ago, CanadianSpaTech said: Use a 2 part epoxy like Devcon plastic weld or Devcon 5 minute epoxy and it will outlast the dinosaurs. You can also use it to plug the open end. Ok thanks. I actually had devcon 5 minute epoxy on hand so I took out the leaking barb and lathered it on. Hopefully it doesn't leak anymore, will test tomorrow. Quote Link to comment Share on other sites More sharing options...
