Alsch Posted August 7, 2020 Report Share Posted August 7, 2020 Hi, We have had our Hot Tub for a week. It has a cover lifter. We noticed yesterday when it was open that it is not level anymore. It dips down to the right. It has been right below that blind evenly across. Nothing looks loose on that side that we can tell. The clip on that side that hooks into the panel broke off when it was lifted but, it doesn’t seem like that would the reason it is crooked now. Anyone have any suggestions or ideas as to what may be causing this. We did call the service department and sent pictures they told us they are not always level and it’s normal. Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted August 7, 2020 Report Share Posted August 7, 2020 Couldn't open the pic. If it changed significantly then something is wrong. Being unlevel is normal for those too inexperienced or lazy to do it right, but it going from level to not means something slipped or gave out. Quote Link to comment Share on other sites More sharing options...
Alsch Posted August 7, 2020 Author Report Share Posted August 7, 2020 Ok thank you for the reply. That’s what we figured but are told it’s normal. Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted August 7, 2020 Report Share Posted August 7, 2020 photo would help. The one you posted won't open. What brand of spa would also help Quote Link to comment Share on other sites More sharing options...
Alsch Posted August 8, 2020 Author Report Share Posted August 8, 2020 My spa is a Sundance but the lift cover I was told was a universal one. Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted August 8, 2020 Report Share Posted August 8, 2020 Could the screen have gone crooked? Is the deck settling? Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted August 8, 2020 Report Share Posted August 8, 2020 With the cover closed and the lifter bar up center the cover on the spa and then lower the bar onto the cover. With the cover closed the lifter down it should sit about 3/4" back of the center crease/fold of the cover and even with the crease all the way across. If it is not even all the way across the cover from side to side you might have to remove the 3 screws from whatever side doesn't line up with the crease/fold and realign the side bar and re-attach the screws once in the proper alignment. The screws that fasten the bar going across the cover from side to side ( 2 sets of 3) should point towards the back of the spa so that when you flip the first half of the cover they do not dig into the cover. When the cover is fully open the screws should point to the ground. Very important. Quote Link to comment Share on other sites More sharing options...
Alsch Posted August 8, 2020 Author Report Share Posted August 8, 2020 Thank you! That’s extremely helpful. 1 Quote Link to comment Share on other sites More sharing options...
