jgy2001 0 Posted July 9, 2020 Report Share Posted July 9, 2020 Getting above ground pool. Built 9' x 14' concrete slab. What kind of thermos vapor insulating floor barrier sheet on top of the concrete slab do you recommend? What kind of adhesive do you recommend? Should we get hardwood flooring adhesive? Urethane flooring adhesive? Thank you. Quote Link to post Share on other sites
jgy2001 0 Posted July 9, 2020 Author Report Share Posted July 9, 2020 Quote Link to post Share on other sites
RDspaguy 559 Posted July 9, 2020 Report Share Posted July 9, 2020 Well, I have almost no above ground pool experience. While I have repaired equipment on many I have only built 2. I have never seen an above ground pool on concrete, so could not advise on what to put under it or how to attach it. Most are on sand, with or without vermiculite, with leveled pavers or piers under the supports. @Pool Clown, @jimmythegreek, got anything? Quote Link to post Share on other sites
jimmythegreek 23 Posted July 10, 2020 Report Share Posted July 10, 2020 Dont do much with above grounds but a slab is something I haven't seen. I would do rigid foam board amd use any type of construction adhesive it's not going anywhere with all the water weight 1 Quote Link to post Share on other sites
jgy2001 0 Posted July 13, 2020 Author Report Share Posted July 13, 2020 We are thinking of these, what would you choose? 1. https://www.amazon.com/gp/product/B01050H8MM/ref=ox_sc_act_title_3?smid=A226NGGGPAUWSH&psc=1 100sqft (2ft Wide) of NASA TECH Commercial Grade Solid White Non Perforated Platinum No Tear Green Energy Radiant Barrier Reflective Insulation Solar Attic Foil Roof Attic House Wrap SCIF RIFD 2. https://www.amazon.com/gp/product/B000BPAULS/ref=ox_sc_act_title_2?smid=A2Q1LRYTXHYQ2K&psc=1 Reflectix BP48010 Double Pack Insulation, 48 in. x 10 ft 3. https://www.amazon.com/gp/product/B0104ZUNDO/ref=ox_sc_act_title_4?smid=A917DJU8KFW86&psc=1 250sqft (4ft Wide) of NASA TECH Commercial Grade Solid Platinum Non Perforated No Tear Green Energy Radiant Barrier Reflective Insulation Solar Attic Foil Roof Attic House Wrap SCIF RIFD 4. https://www.homedepot.com/p/Roberts-120-sq-ft-10-ft-x-12-ft-x-0-006-in-Roll-of-6-mil-Moisture-Barricade-Polyethylene-Underlay-Film-70-115/100578718 120 sq. ft. 10 ft. x 12 ft. x 0.006 in. Roll of 6 mil Moisture Barricade Polyethylene Underlay Film 5. https://www.homedepot.com/p/Roberts-AirGuard-100-sq-ft-40-in-x-30-ft-x-2-mm-5-in-1-Underlayment-with-Microban-for-Laminate-and-Engineered-Wood-Floors-70-105/202299502 AirGuard 100 sq. ft. 40 in. x 30 ft. x 2 mm 5-in-1 Underlayment with Microban for Laminate and Engineered Wood Floors Quote Link to post Share on other sites
