Kenr Posted March 27, 2010 Report Posted March 27, 2010 I recently replaced my circulation pump because the seal went bad and it was leaking water. I got the new pump in and started it up but I noticed the motor seemed to be getting pretty hot. A short while later the pump shut down (overheat protection I assume). Any suggestions, on what can be wrong? The hookup seemed pretty straight forward but I guess I got something wrong. Quote
bart6453 Posted March 27, 2010 Report Posted March 27, 2010 I recently replaced my circulation pump because the seal went bad and it was leaking water. I got the new pump in and started it up but I noticed the motor seemed to be getting pretty hot. A short while later the pump shut down (overheat protection I assume). Any suggestions, on what can be wrong? The hookup seemed pretty straight forward but I guess I got something wrong. I know very little about spa packs specifically....but what I do know is if your voltage is lower than it should be all your equipment will be running at a higher temperature. Quote
d1dennis2009 Posted March 27, 2010 Report Posted March 27, 2010 There are at least acouple of things that could cause a circulation pump to run hotter than the spec. 1. Running at higher voltage than specification 2. Dirty Filter 3. Obstruction in the lines to the circ pump I would double check the pump voltage, since you just replaced it. Quote
Kenr Posted March 27, 2010 Author Report Posted March 27, 2010 I'll have to check the wiring again I guess. Unfortunately it's buried behind the control unit so I have to pull the pump out to check the wiring at the pump itself. Maybe I reversed neutral/hot? I double checked to make sure valves were open and water seemed to running fine. It has a brand new filter (spring drain and clean was the final straw for the seal). Another question. I had to rotate the pump end which involved taking out the 4 long bolts through the motor, rotate and put bolts in. I can't imagine messing that up but can the bolts be overtightened or anything to bind the motor? Although I don't think I tightened them that much. On an additional note the motor overheats and shuts down in about 10 minutes. TIA Quote
THE SPA GUY Posted March 27, 2010 Report Posted March 27, 2010 you might use a mirror to look at the ratings tag, sounds like you voltage on pump is different then before, meaning 110 instead of 220 or vise versa.... Quote
Kenr Posted March 27, 2010 Author Report Posted March 27, 2010 you might use a mirror to look at the ratings tag, sounds like you voltage on pump is different then before, meaning 110 instead of 220 or vise versa.... Grrr... I checked the pump when I got it and can see the tag in the spa and it's 115v which is the listed part for the spa but looking at the old pump it's a 230v. I have no idea of why they list the wrong part in the manual nor why they sent me a 115v when I ordered the part for this spa from the manufacturer. But at least I know what is going on. Thanks I guess I can look into wiring it 115v or ship it back and be down another week Quote
Cavalier Posted March 29, 2010 Report Posted March 29, 2010 Prove the company erred. They should pay for return of the pump and FEDEX Red overnight a new pump as you so properly ordered. you might use a mirror to look at the ratings tag, sounds like you voltage on pump is different then before, meaning 110 instead of 220 or vise versa.... Grrr... I checked the pump when I got it and can see the tag in the spa and it's 115v which is the listed part for the spa but looking at the old pump it's a 230v. I have no idea of why they list the wrong part in the manual nor why they sent me a 115v when I ordered the part for this spa from the manufacturer. But at least I know what is going on. Thanks I guess I can look into wiring it 115v or ship it back and be down another week Quote
Kenr Posted March 29, 2010 Author Report Posted March 29, 2010 It turns out that the control panel easily switches between 115v and 230v motors. I just moved one wire and everything is good now. Still pretty annoying that they don't know what pump they put in their own spa. I know better than to trust the people I order from I should of checked the old pump myself. Quote
bart6453 Posted March 30, 2010 Report Posted March 30, 2010 It turns out that the control panel easily switches between 115v and 230v motors. I just moved one wire and everything is good now. Still pretty annoying that they don't know what pump they put in their own spa. I know better than to trust the people I order from I should of checked the old pump myself. Could have superseded. If so....they should have had the bulletin in the package. Secondarily, it is your responsibility to make sure you are getting the right parts, and to check fitment prior to buttoning up a job. (including voltage) Quote
jesslh Posted May 11 Report Posted May 11 Replaced new circulating pump with new circulating pump. The pump is getting really hot. Word for word it is the same circulating pump that I ordered. So we thought it was bad pump and ordered a new one same spec, same problem. Any thoughts? Quote
waterbear Posted May 12 Report Posted May 12 @jesslh you posted in a 15 year old threads. you will have a better chance of getting you question answered if you start a new thread. Quote
