I'll have to check the wiring again I guess.
Unfortunately it's buried behind the control unit so I have to pull the pump out to check the wiring at the pump itself. Maybe I reversed neutral/hot?
I double checked to make sure valves were open and water seemed to running fine. It has a brand new filter (spring drain and clean was the final straw for the seal).
Another question. I had to rotate the pump end which involved taking out the 4 long bolts through the motor, rotate and put bolts in. I can't imagine messing that up but can the bolts be overtightened or anything to bind the motor? Although I don't think I tightened them that much.
On an additional note the motor overheats and shuts down in about 10 minutes.
TIA
