recycleman Posted October 18, 2009 Report Share Posted October 18, 2009 Have been having problems with the upper control panel not being responsive. The only button that seems to work is the temperature control and only sometimes. When I hold either pump 1 or 2 button for 10 seconds or longer and error message comes up and says"check water level, clean fiters, if this problem persists call for service" Just a bad upper control panel? Or is there something else it could be before I spend the 300 bucks on a new panel? Quote Link to comment Share on other sites More sharing options...
d1dennis2009 Posted October 18, 2009 Report Share Posted October 18, 2009 Hey recycleman, shoot me a contact number and I'll see if I can help! Dennis D1 Tech Rep Quote Link to comment Share on other sites More sharing options...
KeriBerry Posted March 28, 2020 Report Share Posted March 28, 2020 Hi! we have a Dimension One Spas Nautilus hot tub. It has been sitting for about 3 years. We went to power it back on after cleaning it up and re-filling it and it appears to have power but the display panel does nothing. Does it need to be completely replaced or is there a possible troubleshooting problem we can try ourselves first? Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted March 28, 2020 Report Share Posted March 28, 2020 There are many possible troubleshooting problems you can try yourself. How handy are you? Can you use an electrical tester? Why do you think it has power? Quote Link to comment Share on other sites More sharing options...
KeriBerry Posted March 28, 2020 Report Share Posted March 28, 2020 We believe it still has power because it is still cycling at the bottom. Yes we are very handy we have a multi-meter Quote Link to comment Share on other sites More sharing options...
KeriBerry Posted March 29, 2020 Report Share Posted March 29, 2020 ? Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted March 29, 2020 Report Share Posted March 29, 2020 17 hours ago, KeriBerry said: Hi! we have a Dimension One Spas Nautilus hot tub. It has been sitting for about 3 years. We went to power it back on after cleaning it up and re-filling it and it appears to have power but the display panel does nothing. Does it need to be completely replaced or is there a possible troubleshooting problem we can try ourselves first? Does the display light up and show temp or is it that just the buttons don't work when you press them? If it lights up are there any error codes displayed? Quote Link to comment Share on other sites More sharing options...
KeriBerry Posted March 29, 2020 Report Share Posted March 29, 2020 It doesn’t light up at all Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted March 29, 2020 Report Share Posted March 29, 2020 Are there any pumps running? Try disconnecting the topside and see if the pumps run on their own. Power down disconnect topside and restart. Have you tested all the fuses on the board? Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted March 29, 2020 Report Share Posted March 29, 2020 Have you verified that you have voltage going to the spa pack? Quote Link to comment Share on other sites More sharing options...
KeriBerry Posted March 29, 2020 Report Share Posted March 29, 2020 Yes, seems like pumps are running. We walked outside after dinner last night and poof, all the jets were running perfectly, but still no display on the control panel and then the jets just stopped. But you can still hear it cycling water at the bottom. We are going to check all the fuses right now Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted March 29, 2020 Report Share Posted March 29, 2020 Also check for loose controller cable on the board. Could also be chewed wires. Quote Link to comment Share on other sites More sharing options...
d1dennis2009 Posted April 2, 2020 Report Share Posted April 2, 2020 KeriBerry, we specialize in D1 spas and would be happy to troubleshoot it with you, it does sound like the topside it bad and will need replaced. But we can go over the options and verify everything. My number is 760.216.6756 and nae is Dennis Quote Link to comment Share on other sites More sharing options...
