D1 Nautilus Upper Control Panel Problem
recycleman
Have been having problems with the upper control panel not being responsive. The only button that seems to work is the temperature control and only sometimes. When I hold either pump 1 or 2 button for 10 seconds or longer and error message comes up and says"check water level, clean fiters, if this problem persists call for service" Just a bad upper control panel? Or is there something else it could be before I spend the 300 bucks on a new panel?
  • 10 years later...
Hi!
we have a Dimension One Spas Nautilus hot tub. It has been sitting for about 3 years. We went to power it back on after cleaning it up and re-filling it and it appears to have power but the display panel does nothing. Does it need to be completely replaced or is there a possible troubleshooting problem we can try ourselves first?
17 hours ago, KeriBerry said:
Hi!
Does the display light up and show temp or is it that just the buttons don't work when you press them? If it lights up are there any error codes displayed?
Yes, seems like pumps are running. We walked outside after dinner last night and poof, all the jets were running perfectly, but still no display on the control panel and then the jets just stopped. But you can still hear it cycling water at the bottom. We are going to check all the fuses right now
