chateauneufdupape Posted August 26, 2009 Report Share Posted August 26, 2009 I am looking for a large spa and am considering several brands including Artesian Bimini, Arctic Summit or Tundra, Coyote Chieftan Jacuzzi 400 series, D1 Amore, Vision Hydrus, Spaform Prestige 75 and Cal Spas Escape Extreme. I can't seem to find much info on the quality of Cal Spas. http://www.calspas.com/ , Vision (Spa Crest) http://www.visionhottubs.com/vision.asp Spaform http://www.spaform.com/index.php I have had a cheap spa before and want something of high quality, easy to maintain and good support if there are problems or questions that I have. Any comments welcome. I would like to narrow down my choices before I start wet testing. N.B. I live in the UK. Quote Link to comment Share on other sites More sharing options...
Water Boy Posted August 26, 2009 Report Share Posted August 26, 2009 I am looking for a large spa and am considering several brands including Artesian Bimini, Arctic Summit or Tundra, Coyote Chieftan Jacuzzi 400 series, D1 Amore, Vision Hydrus, Spaform Prestige 75 and Cal Spas Escape Extreme. I can't seem to find much info on the quality of Cal Spas. http://www.calspas.com/ , Vision (Spa Crest) http://www.visionhottubs.com/vision.asp Spaform http://www.spaform.com/index.php I have had a cheap spa before and want something of high quality, easy to maintain and good support if there are problems or questions that I have. Any comments welcome. I would like to narrow down my choices before I start wet testing. N.B. I live in the UK. You already have some quality spas on your list in the Arctic Spas, D1, and the Jacuzzi. Some other quality spas you might look at to compare would be HS, Sundance, and Marquis. Those are all some of the best spas manufactures that many on here would recommend. You may find out what all of those brands are in your area, do some research on your local dealers, and go out and check them out. Then try to schedule some wet tests to help make your decision. Good luck in your search. Quote Link to comment Share on other sites More sharing options...
ps558 Posted August 26, 2009 Report Share Posted August 26, 2009 I am looking for a large spa and am considering several brands including Artesian Bimini, Arctic Summit or Tundra, Coyote Chieftan Jacuzzi 400 series, D1 Amore, Vision Hydrus, Spaform Prestige 75 and Cal Spas Escape Extreme. I can't seem to find much info on the quality of Cal Spas. http://www.calspas.com/ , Vision (Spa Crest) http://www.visionhottubs.com/vision.asp Spaform http://www.spaform.com/index.php I have had a cheap spa before and want something of high quality, easy to maintain and good support if there are problems or questions that I have. Any comments welcome. I would like to narrow down my choices before I start wet testing. N.B. I live in the UK. You already have some quality spas on your list in the Arctic Spas, D1, and the Jacuzzi. Some other quality spas you might look at to compare would be HS, Sundance, and Marquis. Those are all some of the best spas manufactures that many on here would recommend. You may find out what all of those brands are in your area, do some research on your local dealers, and go out and check them out. Then try to schedule some wet tests to help make your decision. Good luck in your search. I have seen some Cal-spas they look ok, I think the outside panel are to thin. They are a bear to work on and if they are still using GE motors stay away Quote Link to comment Share on other sites More sharing options...
chateauneufdupape Posted August 26, 2009 Author Report Share Posted August 26, 2009 Waterboy - Thanks for the feedback. I will check out Marquis, Sundance and Hotsprings. ps558 - Thanks for the warning. Quote Link to comment Share on other sites More sharing options...
Tomab Posted August 26, 2009 Report Share Posted August 26, 2009 I am looking for a large spa and am considering several brands including Artesian Bimini, Arctic Summit or Tundra, Coyote Chieftan Jacuzzi 400 series, D1 Amore, Vision Hydrus, Spaform Prestige 75 and Cal Spas Escape Extreme. I can't seem to find much info on the quality of Cal Spas. http://www.calspas.com/ , Vision (Spa Crest) http://www.visionhottubs.com/vision.asp Spaform http://www.spaform.com/index.php I have had a cheap spa before and want something of high quality, easy to maintain and good support if there are problems or questions that I have. Any comments welcome. I would like to narrow down my choices before I start wet testing. N.B. I live in the UK. Before I bought my spa I tested both the Arctic Tundra and Summit. I went with the Tundra due to the fact it "felt" like a much larger tub and less confined even though they both have the same outer dimensions. I love the Tundra and I have had no problems at all so far. I've had the tub since about mid April. I have a Tundra LE with Deluxe Northern Lights, Therapy Air and no Onzen(just Arctic Ozone). As far as Arctic customer service.....the verdict is still out. Just my 2 cents. Quote Link to comment Share on other sites More sharing options...
spatech (the unreal one) Posted August 26, 2009 Report Share Posted August 26, 2009 Waterboy - Thanks for the feedback. I will check out Marquis, Sundance and Hotsprings. ps558 - Thanks for the warning. I'm not sure what you have in your area but here in the US there are a few good spa makers. Since I have no idea what possibilities you have where you are I'd suggest you start on-line with a long list like Arctic, Artesian, Beachcomber, Caldera, D1, Hot Spring, Jacuzzi, Marquis and Sundance. After using their websites to see who might be local to you visit as many as you can, narrow it down to 3 or so dealers that you like and wet test the models you like. Take your time. Quote Link to comment Share on other sites More sharing options...
d1dennis2009 Posted August 27, 2009 Report Share Posted August 27, 2009 I would definitely recommend you check out the Amore Bay and the Lotus Bay from D1 Spa, they are both large well equipped spas. If you need help locating a dealer in th area, I would be happy to assist. D1 has a strong presence in the UK and they have alot of great service technicians as well. Dennis Quote Link to comment Share on other sites More sharing options...
Spa_Newbie Posted August 31, 2009 Report Share Posted August 31, 2009 I've just recieved a 'large' Sundance Hawthorne... http://www.sundancespas.com/680Series/Custom-Hot-Tubs.html So far very please with it - can easily accommodate 5 or 6 adults, but only had it less than a week! Quote Link to comment Share on other sites More sharing options...
d1dennis2009 Posted August 31, 2009 Report Share Posted August 31, 2009 Good Morning, I would be happy to put you in contact with our European Sales Manager, he can assist you in find a location to check out the Amore Bay or the Lotus Bay. D1 Spas has a strong presence in the UK and we would appreciate the opportunity to show you one of our premier products. Shoot me an email with your information, I will forward on to the appropriate person to follow assist you in your search. Cheers, Dennis Porter D1 Spas Technical Support Rep. Quote Link to comment Share on other sites More sharing options...
Stuart A Posted August 31, 2009 Report Share Posted August 31, 2009 I live in the UK. I live near Reading if you are within a reasonable distance I can give you the names and addresses of dealers for La Spa, Sundance, Dimension 1 and Hotspring who are all within a twenty minute drive from me, there is also a dealer on the South coast who sells Monarch and Spaform. Quote Link to comment Share on other sites More sharing options...
