Mike233 Posted August 12, 2007 Report Share Posted August 12, 2007 New to the board and notice most people have done lots of reseach on thier respective spa. I am trying to decide on a gunite spa or a portable above ground spa. Maybe even a Spool??? We have a small back yard to work with. I realize money is a big differnce between the gunite and portables but any other glaring considerations? Thanks Mike in So Cal Quote Link to comment Share on other sites More sharing options...
D.P. Roberts Posted August 13, 2007 Report Share Posted August 13, 2007 New to the board and notice most people have done lots of reseach on thier respective spa. I am trying to decide on a gunite spa or a portable above ground spa. Maybe even a Spool??? We have a small back yard to work with. I realize money is a big differnce between the gunite and portables but any other glaring considerations? Thanks Mike in So Cal A few suggestions: 1) Gunite is usually considered a "permanent" part of your home, whereas portable hot tubs are not. This may affect your house's value, loans you may get, insurance, etc. 2) Gunite spas are often larger, but usually have smaller pumps and fewer jets. Few people who want real "therapy" get gunite tubs. 3) Although newer surfaces are smoother, the surface of most portable tubs will be smoother than gunite. 4) I've known several people who have gone the "spool" route. If you think you might want to use it as a pool most of the time, that's probably a good idea. However, that's a lot of water to heat up if you want to use it as a spa. 5) If you really want the "built in" look of a gunite pool, consider an in-ground spa from one of the portable spa manufacturers. For example, Sundance sells in-ground versions of several of its spas. Bullfrog is in the process of introducing "jet packs" for gunite spas, which might be interesting as well. Quote Link to comment Share on other sites More sharing options...
Mike233 Posted August 13, 2007 Author Report Share Posted August 13, 2007 New to the board and notice most people have done lots of reseach on thier respective spa. I am trying to decide on a gunite spa or a portable above ground spa. Maybe even a Spool??? We have a small back yard to work with. I realize money is a big differnce between the gunite and portables but any other glaring considerations? Thanks Mike in So Cal A few suggestions: 1) Gunite is usually considered a "permanent" part of your home, whereas portable hot tubs are not. This may affect your house's value, loans you may get, insurance, etc. 2) Gunite spas are often larger, but usually have smaller pumps and fewer jets. Few people who want real "therapy" get gunite tubs. 3) Although newer surfaces are smoother, the surface of most portable tubs will be smoother than gunite. 4) I've known several people who have gone the "spool" route. If you think you might want to use it as a pool most of the time, that's probably a good idea. However, that's a lot of water to heat up if you want to use it as a spa. 5) If you really want the "built in" look of a gunite pool, consider an in-ground spa from one of the portable spa manufacturers. For example, Sundance sells in-ground versions of several of its spas. Bullfrog is in the process of introducing "jet packs" for gunite spas, which might be interesting as well. Quote Link to comment Share on other sites More sharing options...
Mike233 Posted August 13, 2007 Author Report Share Posted August 13, 2007 New to the board and notice most people have done lots of reseach on thier respective spa. I am trying to decide on a gunite spa or a portable above ground spa. Maybe even a Spool??? We have a small back yard to work with. I realize money is a big differnce between the gunite and portables but any other glaring considerations? Thanks Mike in So Cal A few suggestions: 1) Gunite is usually considered a "permanent" part of your home, whereas portable hot tubs are not. This may affect your house's value, loans you may get, insurance, etc. 2) Gunite spas are often larger, but usually have smaller pumps and fewer jets. Few people who want real "therapy" get gunite tubs. 3) Although newer surfaces are smoother, the surface of most portable tubs will be smoother than gunite. 4) I've known several people who have gone the "spool" route. If you think you might want to use it as a pool most of the time, that's probably a good idea. However, that's a lot of water to heat up if you want to use it as a spa. 5) If you really want the "built in" look of a gunite pool, consider an in-ground spa from one of the portable spa manufacturers. For example, Sundance sells in-ground versions of several of its spas. Bullfrog is in the process of introducing "jet packs" for gunite spas, which might be interesting as well. Thanks D.P. I will check out Sundance Quote Link to comment Share on other sites More sharing options...
TravelingSpaGuy Posted August 13, 2007 Report Share Posted August 13, 2007 2) Gunite spas are often larger, but usually have smaller pumps and fewer jets. Few people who want real "therapy" get gunite tubs. why would someone consider this more therapy? Gunite looks nicer with built in but costs more to install and maintaine (unless Gas then very similar), while portable spas have better filtration and take less maintence and have better jetting. I wouldnt suggest the inground shells that sundance offers because you still having the plumming like in a gunite tub outside the spa, if you want an inground look I suggest halfway recessing a real tub because they are easier to enter and look nice as well, this way you can give access to your interior components and get the nicer jets, seating, maintance and cost of opportation Quote Link to comment Share on other sites More sharing options...
tenchin Posted June 25, 2009 Report Share Posted June 25, 2009 you can give access to your interior components and get the nicer jets, seating, maintance and cost of opportation sonnerie portable gratuite Quote Link to comment Share on other sites More sharing options...
