A few suggestions:
1) Gunite is usually considered a "permanent" part of your home, whereas portable hot tubs are not. This may affect your house's value, loans you may get, insurance, etc.
2) Gunite spas are often larger, but usually have smaller pumps and fewer jets. Few people who want real "therapy" get gunite tubs.
3) Although newer surfaces are smoother, the surface of most portable tubs will be smoother than gunite.
4) I've known several people who have gone the "spool" route. If you think you might want to use it as a pool most of the time, that's probably a good idea. However, that's a lot of water to heat up if you want to use it as a spa.
5) If you really want the "built in" look of a gunite pool, consider an in-ground spa from one of the portable spa manufacturers. For example, Sundance sells in-ground versions of several of its spas. Bullfrog is in the process of introducing "jet packs" for gunite spas, which might be interesting as well.
Thanks D.P. I will check out Sundance
