calsap Posted October 21, 2023 Report Share Posted October 21, 2023 Hi All, Need some advice. My 2001 Sundance Capri gives a watchdog error after being off a few weeks. It gives a watchdog error right away on startup. Dashes and other text are flashing. I opened it up and found mice had eaten through the temp sensor wire. I wired it back up. Checked the capacitors and they look fine. I figured fixing the wire would fix the issue. Flo sensor and hi limit are fine. Turned it off and on a few times and still the same, even waiting overnight. The error and the chewed wire seemed like too much of a coincidence for something else to be the issue, but the error won't go away. Any thoughts before I change the capacitors anyway? Thank you! Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted October 23, 2023 Report Share Posted October 23, 2023 On 10/21/2023 at 6:11 PM, calsap said: Dashes and other text are flashing What other text? I would be changing temp sensor before capacitors. Quote Link to comment Share on other sites More sharing options...
calsap Posted October 25, 2023 Author Report Share Posted October 25, 2023 I checked the resistance on the temp sensor and the high limit and they both checked out. The filter was out too. The screen doesn't just show dashes. The am/pm/lock small text were flashing. Thanks Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted October 25, 2023 Report Share Posted October 25, 2023 7 hours ago, calsap said: checked the resistance on the temp sensor and the high limit and they both checked out. According to what? How many ohms on each? On 10/23/2023 at 6:43 PM, CanadianSpaTech said: would be changing temp sensor 1 Quote Link to comment Share on other sites More sharing options...
calsap Posted October 25, 2023 Author Report Share Posted October 25, 2023 I was looking at the chart here. https://www.spaandpoolsource.com/sundancespastemperaturesensordiagnostic.aspx The spa had been off and it was around 70F outside. I think the readings were around 35kohm for the temp sensor and 30kohm for the hi limit. Quote Link to comment Share on other sites More sharing options...
