Calling out techs, Bullfrog - maintenance
MrX
Hello,
I know that we have couple guys here that are experts.
My house came with A7 2015 bullfrog
I peaked inside and it seems to have two pumps, one pump has some sweating on the shaft ( bad seal ) the other pump looks pristine.
But it looks like one pump was replaced
Both are XP2 2.5 HP
One is made in Mexico US Motors and other Century made in China.
the leaking one is US Motors
I will rebuild the US Motors one, and keep as spare … what new pump should I buy as direct replacement ?
Should I replace heating element ? Even when it looks visually great and resistance is at 15
56 minutes ago, CanadianSpaTech said:
I would center the heater element a little better. If it moves and touches the metal tube it will hot spot and burn out. Heater elements either work or they don't so if it is working it's good and no need to replace it.
Thank you I will do that!
any suggestion on replacement pump?
I read that LX pumps are better and cheaper ?
Should I just find LX 2.5HP with 2”/2” and that should be direct fit ?
thank you
