6010fd12 Posted July 4 Report Share Posted July 4 2013 Jetsetter. I winterized the tub with RV antifreeze to keep it safe before I moved and now when I cleaned off the antifreeze that was mostly dried it has left a stain. Is there anyway to remove this stain? Soak in Vinegar? Bleach? Fiberglass stain remover? Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted July 4 Report Share Posted July 4 First go-to is a magic eraser. If that doesn't work, try ascorbic acid (vitamin c tablets) or muriatic acid water (50/50), next try bleach water (1/2 cup/gallon). If those don't work let us know. 3 Quote Link to comment Share on other sites More sharing options...
6010fd12 Posted July 4 Author Report Share Posted July 4 55 minutes ago, RDspaguy said: First go-to is a magic eraser. If that doesn't work, try ascorbic acid (vitamin c tablets) or muriatic acid water (50/50), next try bleach water (1/2 cup/gallon). If those don't work let us know. Gotcha. I'll give tho a try in the morning. How long do I leave it it soak in the muriatic acid and bleach if I have to take that route? Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted July 4 Report Share Posted July 4 Just scrub a spot for starters. If you see it's coming off, keep at it. I wouldn't let either soak, or you may create more problems than you solve. 1 Quote Link to comment Share on other sites More sharing options...
Cusser Posted July 4 Report Share Posted July 4 11 hours ago, 6010fd12 said: How long do I leave it it soak in the muriatic acid and bleach if I have to take that route? If you try this: Don't mix, danger !!!! One at a time, rinse in between. 1 1 Quote Link to comment Share on other sites More sharing options...
6010fd12 Posted July 4 Author Report Share Posted July 4 1 hour ago, Cusser said: If you try this: Don't mix, danger !!!! One at a time, rinse in between. Yup, you should never mix chemicals that you don't know what the resulting reaction will be. Sorry I probably worded that wrong. I ment if the muriatic acid didn't work I would try the bleach. Quote Link to comment Share on other sites More sharing options...
6010fd12 Posted July 4 Author Report Share Posted July 4 Also while I have this topic open any tips for getting stains out the inside of the cover? I'm guessing same procedure as mentioned above or slightly less harsh chemicals? Quote Link to comment Share on other sites More sharing options...
