westernk Posted December 11, 2021 Report Share Posted December 11, 2021 Hey all.. My Arctic Yukon which I've had for just 4 years has begun to show rust deposits that settle on the chrome part of the Jets. They do wipe off with little effort and the filters regularly have this same brownish deposit on em. This deposit now is tinting the water to a green colour (most likely yellow water in a blue shell?) The PH is held at 7.6 TA is about 50 FCL at 5ppm Salt at 2300 ppm So the water is well balanced. Water was replaced in October and I always use clean start as part of my cleanout to refill procedure Seeklear metal remover seems to have a temporary effect. Does anyone have any clues to whether it truly is the components rusting or is it copper in The water? Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted December 13, 2021 Report Share Posted December 13, 2021 If it wipes off it's the water. Quote Link to comment Share on other sites More sharing options...
dashmer Posted December 14, 2021 Report Share Posted December 14, 2021 If it is the water, your source is obviously full of iron and possibly other metals. If you did not use one on last fill, I recommend one of those hose line filters (x10 I think or similar) to try and pull most of that out before it gets in your tub. Quote Link to comment Share on other sites More sharing options...
westernk Posted January 2, 2022 Author Report Share Posted January 2, 2022 Thanks everyone will get a pre filler Quote Link to comment Share on other sites More sharing options...
