Bryan insko Posted August 4, 2021 Report Share Posted August 4, 2021 My air flow adjuster leaks only when jets are off . Maybe the tub is over filled . Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted August 4, 2021 Report Share Posted August 4, 2021 Yep, that will do it. Once it starts leaking it can create a siphon that can drain it quite low. Quote Link to comment Share on other sites More sharing options...
Bryan insko Posted August 4, 2021 Author Report Share Posted August 4, 2021 I will drain some water out and hopefully it stops leaking thanks Quote Link to comment Share on other sites More sharing options...
Bryan insko Posted August 4, 2021 Author Report Share Posted August 4, 2021 so I drained some water out but it still leaks any ideas Quote Link to comment Share on other sites More sharing options...
cranbiz Posted August 5, 2021 Report Share Posted August 5, 2021 There should be a check valve someplace in the air circuits. I would look to see if there is one and be concentrating on that. Quote Link to comment Share on other sites More sharing options...
