noah Posted July 15, 2021 Report Share Posted July 15, 2021 I have some broken spa jets (20093-001), and I've ordered the replacement 6541-288. I was told the inserts were compatible. Is that true? If that isn't true, which it seems not to be considering what I've managed to pull apart so far. Do I now have to take the spa wall off and replace the whole mechanism (connecting the spa pipes and such)? Thanks for any help, Noah What's left of the old one after I managed to remove the top piece, and after are pics of the new insert. Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted July 15, 2021 Report Share Posted July 15, 2021 Can't say I've ever seen those particular jets. Post some pics of the pieces that came out. @CanadianSpaTech? Quote Link to comment Share on other sites More sharing options...
noah Posted July 15, 2021 Author Report Share Posted July 15, 2021 Here's what I pulled out (these pieces are broken; the picture of what remains is above): Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted July 15, 2021 Report Share Posted July 15, 2021 What year is the spa. https://www.hottuboutpost.com/jacuzzi-spa-power-pro-rx-jet-with-stainless-steel-escutcheon-20093-001/ Jet has been discontinued by the manufacturer and is no longer available. See JAC6541-288 which will work in place of this item - depending on your spa model/year. Jacuzzi® Spa Power Pro RX Jet With Stainless Steel Escutcheon, Includes O-ring, Washer and Nut. Factory original Jacuzzi® part, no imitations here. 3 1/2 inch jet face. 3.9 inches long. Used in pre-2013 models. 1 Quote Link to comment Share on other sites More sharing options...
noah Posted July 15, 2021 Author Report Share Posted July 15, 2021 It’s from 2013 (I believe late 2013). The jet is discontinued. But I was told the inserts are compatible… struggling to confirm if that is true. Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted July 15, 2021 Report Share Posted July 15, 2021 Have a look here: https://www.guillens.com/images/JAC/Pdf/JPS/2014-1 Parts Catalog.pdf 1 Quote Link to comment Share on other sites More sharing options...
noah Posted July 19, 2021 Author Report Share Posted July 19, 2021 I finally spoke to Jacuzzi - from 20093-001, I need to replace the complete jet (back and front) and recommended replacement is 6541-288 with 6541-634 ring. (Note, Jacuzzi had used 6541-566 for a while but that is not what is recommended to replace it with now). 1 Quote Link to comment Share on other sites More sharing options...
