blang Posted October 26, 2020 Report Share Posted October 26, 2020 (edited) I have had my tub empty for the summer, just filled it and went to power up last night. The top side control panel lights up, and goes through its boot up process and just as it is going to start the pump it reboots and starts the light up process again. I have powered down, unplugged the Pump, control panel, and light connectors from the spa pack and reconnected. At one time i would get a click from the pump just before it would reboot. Then after power down a couple more times the pump actually started up for about 1 second and then continued the reboot loop. I have left the tub powered off over night and today when I power it up I am back to just the reboot loop, not even a click from the pump. I have replaced the 25amp fuse (not replaced the 20amp yet), also tried powering up without the pump connected to the spa pack. Still getting just the reboot loop. Any assistance is greatly appreciated before I bring in a service tech. Is there anything I can test on the board itself or look for? Thanks! Edited October 26, 2020 by blang typo Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted October 26, 2020 Report Share Posted October 26, 2020 It is going to be the low voltage power supply on the board. It is repairable...if you have the right electronics repair technician. Where are you located 1 Quote Link to comment Share on other sites More sharing options...
blang Posted October 26, 2020 Author Report Share Posted October 26, 2020 Thanks for the reply! I am in Barrie, ON. I'm assuming it's a board level repair? I wish I were confident in my soldering skills 🙃 Quote Link to comment Share on other sites More sharing options...
blang Posted October 26, 2020 Author Report Share Posted October 26, 2020 Now, without the top side keypad connected I am getting a click like it's trying to fire the pump on every reboot. But still getting constant boot loop. Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted October 26, 2020 Report Share Posted October 26, 2020 PM SENT 1 Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted October 26, 2020 Report Share Posted October 26, 2020 1 hour ago, CanadianSpaTech said: It is going to be the low voltage power supply on the board. It is repairable...if you have the right electronics repair technician. Where are you located Agreed. 👍 1 Quote Link to comment Share on other sites More sharing options...
Mattevans Posted April 27, 2021 Report Share Posted April 27, 2021 Have this same boot loop on a gecko in.xe with a touch screen control. The screen sits at initializing, and there is a relay switch every 20 seconds or so. How were you able to repair this? Quote Link to comment Share on other sites More sharing options...
Spatrecking Posted May 1, 2021 Report Share Posted May 1, 2021 Hi, my neighbour has a similar problem with his Spa. He's managed to get a replacement Spa Pack board, however it's a later edition not compatible with his controller. Without a schematic I'm shooting in the dark a little but his fault appears to be LV related. Controller cycles and the pump starts then stops. I've swapped from the board a little 12v 3A relay as suspected the LV circuit not latching. Any advice on components to swap would be appreciated! Or if anyone can provide a link for a schematic that would be great. 30 years of Electronics experience I'm confident I could get this repaired before he spends 1000 on a new controller and Spa pack! Quote Link to comment Share on other sites More sharing options...
MikeeT Posted July 29, 2021 Report Share Posted July 29, 2021 On 10/26/2020 at 4:04 PM, CanadianSpaTech said: It is going to be the low voltage power supply on the board. It is repairable...if you have the right electronics repair technician. Where are you located I’m in Barrie as well, having the same problem.. my hot tub actually shows 295 r 2 LL5 any ideas? It’s just rebooting and clicking. Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted July 29, 2021 Report Share Posted July 29, 2021 1 hour ago, MikeeT said: any ideas? 1 hour ago, MikeeT said: low voltage power supply CCR Technologies Guelph,on 1 Quote Link to comment Share on other sites More sharing options...
