rmcderm313 Posted October 1, 2020 Report Share Posted October 1, 2020 Hi All, I'm replacing a jet pump and I'm curious about how to handle the prime barb/hose. My new pump did not come with a barb. Is it possible to move it from the old pump to the new pump? Or is that not advised? Is it normally installed with a silicone adhesive or just a sealant? I want to make sure I have a barb ready if I can't transfer it, that is why I'm asking the question instead of just trying. When installing, what is the advised sealant to use on the threads if any? Thanks, Rob Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted October 1, 2020 Report Share Posted October 1, 2020 Swap it over if needed no sealant required but make sure the o ring gets transferred over as well. You could use a wrap of Teflon tape but it is not required. Don't over tighten it or it will break. 1 Quote Link to comment Share on other sites More sharing options...
rmcderm313 Posted October 1, 2020 Author Report Share Posted October 1, 2020 @CanadianSpaTech I'll take 'I told you so' for $1,000 Alex... I guess I tightened it a hair too much. I put a plug in place of the prime tube for now. How important are these primer tubes?? Thanks, Rob Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted October 1, 2020 Report Share Posted October 1, 2020 1 minute ago, rmcderm313 said: How important are these primer tubes Yes you can cap them but know water will not flow through them and any water left in the line may get stagnant over time. Always best to do the job right if possible. 1 Quote Link to comment Share on other sites More sharing options...
rmcderm313 Posted October 1, 2020 Author Report Share Posted October 1, 2020 1 minute ago, CanadianSpaTech said: Yes you can cap them but know water will not flow through them and any water left in the line may get stagnant over time. Always best to do the job right if possible. Roger that. On order. Quote Link to comment Share on other sites More sharing options...
