We have a high pH level and have attempted to adjust the sanitizer output. The output level is stuck at 60%
I have attempted to adjust the output by pushing the less button.  It will go to 40% but will not go any lower. And then it returns to 60%I have also attempted to make adjustments to the Easytouch control system panel.  I followed the instruction booklet and disabled the Intellichlor unit on the panel.  However, no change was made, on the slide panel.   If I turn off power to the Intellichlor unit at the pentair power box it will also shut off the pool pump.  What is your advice?
Share this post
Link to post
I wouldn't call myself a salt system expert but it sounds like you need to clean the cell.  High pH is a killer for salt cells which is ironic since they tend to raise the pH.
  • Like 1
Share this post
Link to post
