Ndx Posted August 10, 2020 Report Share Posted August 10, 2020 Tub was set to 100F Circulation set to 24h 89.6 outside and sun beating on it ... I wonder if that's the problem. Thx Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted August 10, 2020 Report Share Posted August 10, 2020 Does the spa even have a small circulation pump that is supposed to run 24 hours? Or does it use the main 2 speed pump for filtration and heat? If it uses the main pump duration should be set at 2 hours per 12 hour period 2 times a day = 4 hours out of 24. 1 Quote Link to comment Share on other sites More sharing options...
Ndx Posted August 11, 2020 Author Report Share Posted August 11, 2020 1 hour ago, CanadianSpaTech said: Does the spa even have a small circulation pump that is supposed to run 24 hours? Or does it use the main 2 speed pump for filtration and heat? If it uses the main pump duration should be set at 2 hours per 12 hour period 2 times a day = 4 hours out of 24. @canadianspatech 2 x 2 speed pumps it, uses low speed. Really I had it running for 24hrs ... For a week Is 4 hours really enough ? Thank you Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted August 11, 2020 Report Share Posted August 11, 2020 Yes, it is. You are overheating your spa and burning up your motor and seal. Not good for your circuit board relays either. Listen to @CanadianSpaTech, this is not his first rodeo.😉 1 Quote Link to comment Share on other sites More sharing options...
Ndx Posted August 11, 2020 Author Report Share Posted August 11, 2020 Thx, My Manual said at least 8 hours minimum "Spas with adjustable filter cycles should be operated a minimum of 8 hours a day to remove suspended particles that may exist.( 4 hours per a 12 hour period)" So lol, I figured 24 hrs will be better Hopefully I didn't destroy anything in first week of owning spa lmao! Quote Link to comment Share on other sites More sharing options...
