Fried Pentair Heater logic board? (Help needed)
Hello!  I installed a Pentair IntelliConnect controller today.
I wired up the main pump (Intelliflo) and SWCG (IntelliChlor) via RS-485 cable + dedicated power supplies,  as well as a booster pump to the first relay.
Everything peachy so far.
Next up, I was going to wire a MasterTemp HD400 to the "Heater" relay on the controller.
I followed these instructions:  (Page 30)
Basically, I cut the fireman's switch jumper cable, and "extended" it into the controller's Heater relay, so that it would close the circuit.
As far as I can tell, that's the right way to do it, but the controller wouldn't turn on the heater.  I restored the jumper cable, and now the heater does not turn on at all.  (There is power going to it, which leads me to believe I somehow fried the logic board).
Is this the right way to set up the controller?  Did I miss anything obvious? (Any help would be appreciated so that I don't end up killing another board once I replace it)
Link to post
Gotcha. I am not a pool heater pro, but I notified a good pool guy who should answer shortly.
From what I can see in the manual and based on your description it would seem you wired it correctly. I am at a loss as to why it would have damaged anything.
Link to post
Thanks! I’ll wait.
I’ve been racking my brains on this. The only thing I can think of, is that I ran the controller cable alongside the 240v power lines, and that might’ve induced a bit of current on it, maybe enough to damage the board.   Other than that, I’m at a loss.
Link to post
That is a theoretical possibility. But I have never seen wire routing be an issue on a pool pad, and I have done many new pads and run my wiring very neat and clean.
It is nice to run into someone who understands induction, however. I am guessing you are an electrician?
Link to post
