Help with test strip read
bigroo42
Just don't over use test strips it will only cost you money and you will over use chemicals. Does it look clean and smell clean chances are it's good. Once a week should be all you need. Use a bit of spa shock weekly. Ideally 6 hours before cleaning filters so the filters have time to pick up any suspended organic contaminants (all the stuff that comes off your body). If you have paper pleated filters clean them weekly and soak them in filter wash every 6 weeks for a deeper cleaning. Clean filters are the key to using less products. Removing the organic contaminants on a regular basis will allow your sanitizer to be more effective for a longer period of time and keep up the flow of water through the system.
