Drain Valve leaking
Hello I have 2004 Hot Springs sovereign ii. The right drain plug is leaking, under the filter department. I just need to know how I can replace it? I can't seem to get access to it thru the service panel. Is there another way to access it if I remove another panel? There are two drain plugs on the bottom of the spa, the one that is right under the filter area. I will try to post pictures up soon. Any hep would be great.
Well, we need to know if this is a pipe thread drain (which seals through the threads) or a plug that seals with a rubber seal or O-ring.
Or is it a hose bib where a garden hose can attach?  If so, just get a sealing cap from the hardware store !!
  • 1 year later...
