bigtime1204 Posted September 22, 2010 Report Share Posted September 22, 2010 I am new to tubing (3) months now. I am having a foaming issue that I can't seem to solve. I have a Bromine sanatizing system and all the #s look good on my testing through titration. What have I tried you might ask. De- Foaming agent added to the water (Did not work and did not want to add too much more for fear or doing the reverse thing and make more foam). I tried by bring up the calcium hardness an no good. Tried emzymes added to the water to break up the maybe oils or soap from clothing. Next I was going to try the scum ball. I shock weekly with Bleach and was wondering if the bleach could cause foaming. By the way the foam is clean and depleates fast when pumps and blower are off. Water is also clear at that time. Any help would be appricated, before I dump the water and start over again. Thanks Quote Link to comment Share on other sites More sharing options...
Hillbilly Hot Tub Posted September 22, 2010 Report Share Posted September 22, 2010 You are 3 months in with bromine, you are due for a water change. your TDS is more than likly getting high. Quote Link to comment Share on other sites More sharing options...
bigtime1204 Posted September 22, 2010 Author Report Share Posted September 22, 2010 OK I did say "New" TDS I guess is Total Dissolved Solids? 3 months with new spa, ozonator, bromine and "Change the Water? Why? I've heard 6 months to a year if kept right. Basically I'm the only one using it. I will have the TDS level checked. The water is clear at idle (No Pumps). Thanks Quote Link to comment Share on other sites More sharing options...
waterbear Posted September 23, 2010 Report Share Posted September 23, 2010 OK I did say "New" TDS I guess is Total Dissolved Solids? 3 months with new spa, ozonator, bromine and "Change the Water? Why? I've heard 6 months to a year if kept right. Basically I'm the only one using it. I will have the TDS level checked. The water is clear at idle (No Pumps). Thanks Bromine spas need a water change every 3-4 months PARTICULARLY if you have an ozonator since they have a tendency to oxidize the bromide bank in your water into nonrenewable bromates instead of hypobromous acid, your active bromine sanitizer. Realize that with the higher bather to water ratio in a spa even one bather is about the same as having a pool party of 20 people in an average 12k gallon pool! The only way to get rid of the buildup of organics and oxidation byproducts such as bromates is by a drain and refill. If you are foaming I suspect that the orgainics in your water have finally gotten too high. As far as "6 months to a year" I will bet you heard that from a dealer trying to close a sale and NOT from a hot tub owner or service tech! Quote Link to comment Share on other sites More sharing options...
Hillbilly Hot Tub Posted September 23, 2010 Report Share Posted September 23, 2010 OK I did say "New" TDS I guess is Total Dissolved Solids? 3 months with new spa, ozonator, bromine and "Change the Water? Why? I've heard 6 months to a year if kept right. Basically I'm the only one using it. I will have the TDS level checked. The water is clear at idle (No Pumps). Thanks Acid water is clear too. Clear water does not mean its good water. Water bear is right (usually is ) whoever told you 6 months to a year is wrong, i bet if you read your bromine tablet bottle is says anywhere from 30 days to 90 days. Salt systems, such as Genesis or the like, that create bromine can get a year IF you are very careful about what is added to the water. Quote Link to comment Share on other sites More sharing options...
bigtime1204 Posted September 26, 2010 Author Report Share Posted September 26, 2010 Draining The tub right now. Will not add other than what is essential in the future. Should I add Boric acid after shes up for a while? Will that help!! Thanks for all your inputs! Again all this is new to me. Quote Link to comment Share on other sites More sharing options...
waterbear Posted September 27, 2010 Report Share Posted September 27, 2010 Water bear is right (usually is ) Waddya mean "usually"!?!?!?!?! Quote Link to comment Share on other sites More sharing options...
bigtime1204 Posted September 27, 2010 Author Report Share Posted September 27, 2010 Back up and running and NO Foam!. Thank to all that contributed to my recent delemia. Quote Link to comment Share on other sites More sharing options...
Mikey_in_NY Posted September 27, 2010 Report Share Posted September 27, 2010 You've probably already worked it out by now, but it's important to keep soaps and oils down to a minimum if you want to keep your water quality good for the full 3 months, and just as importantly avoid foaming. If it's realistic get everyone to shower (or at least rinse off) before getting in the tub, also just hang out swimwear to dry instead of using the washer - they will stay clean thanks to water sanitization. Better still don't wear swimwear at all if possible! I certainly learned the hard way last year as a new tub owner, and had to change the water after only a few weeks due to foaming. Anti-foam works for an hour or two, but is basically useless after that, and fliters can't deal with soap. The only real answer is a water change. Quote Link to comment Share on other sites More sharing options...
bigtime1204 Posted September 28, 2010 Author Report Share Posted September 28, 2010 She's good to go now. Will keep my mind open with the body rinse and clothing. Thanks Quote Link to comment Share on other sites More sharing options...
footie Posted September 29, 2010 Report Share Posted September 29, 2010 I am sure I read on here that Anti-forming liquid either effected the reading you got for your test kit or effected your water quality. I intend to never use my supply that came with the tub if I can possibly help it. Quote Link to comment Share on other sites More sharing options...
SparkysPool Posted October 6, 2010 Report Share Posted October 6, 2010 It's the left over soap in your bathing suits from detergent washing. I had the same problem. Sparky Quote Link to comment Share on other sites More sharing options...
bigtime1204 Posted October 8, 2010 Author Report Share Posted October 8, 2010 It's the left over soap in your bathing suits from detergent washing. I had the same problem. Sparky No it was the extra crap I was adding thinking I was helping. I was new and nieve. I'm learning and she running fine with bubbles coming from the blower like it should. Thanks to all on here who helped me out. Quote Link to comment Share on other sites More sharing options...
