beleive Posted December 11, 2008 Report Share Posted December 11, 2008 I have bullfrog spa,love the spa but hate low temp.The control panel reads 104 but its actually 101-102.Which dealer says within specs.The bullfrog has balboa equip. does anyway have a way to get temp up??Id like to see 106-107 for real.Doesnt look like Im the only one that doesnt like the low temp.My spa is outside when its cold out 101 doesnt cut it.Thanks for any help. Quote Link to comment Share on other sites More sharing options...
beleive Posted December 11, 2008 Author Report Share Posted December 11, 2008 I have bullfrog spa,love the spa but hate low temp.The control panel reads 104 but its actually 101-102.Which dealer says within specs.The bullfrog has balboa equip. does anyway have a way to get temp up??Id like to see 106-107 for real.Doesnt look like Im the only one that doesnt like the low temp.My spa is outside when its cold out 101 doesnt cut it.Thanks for any help. Took side cover off today,I have two heat sensor that go into the heater,Im assuming one read temp coming in and the other tells when to turn heater on and off,my sensor part # are 30344. also has M7 on it.Hoping some comes across this give me some help here.THanks Quote Link to comment Share on other sites More sharing options...
Spatech31 Posted January 17, 2009 Report Share Posted January 17, 2009 I have bullfrog spa,love the spa but hate low temp.The control panel reads 104 but its actually 101-102.Which dealer says within specs.The bullfrog has balboa equip. does anyway have a way to get temp up??Id like to see 106-107 for real.Doesnt look like Im the only one that doesnt like the low temp.My spa is outside when its cold out 101 doesnt cut it.Thanks for any help. Took side cover off today,I have two heat sensor that go into the heater,Im assuming one read temp coming in and the other tells when to turn heater on and off,my sensor part # are 30344. also has M7 on it.Hoping some comes across this give me some help here.THanks There is no way to raise temp to 107 + . The spa control is locked out at 104 because it has been legislated that no spa reach over that point.I have investigated this issue many time and the answer is always the same that its not possible. Quote Link to comment Share on other sites More sharing options...
Pathfinder Posted January 18, 2009 Report Share Posted January 18, 2009 Its not legislation its guidelines set by the industry & Independent testing companies like UL. Anything after the end of 05 digital packs no longer have override dip switches. There are ways to override by going into the programming of the board itself but you will void your warranty and most likely screw up your board if not done properly which usually happens. Its doubtful you will find anyone with the proper equip & programming software to do it. You are most likely gonna have to suck it up. Quote Link to comment Share on other sites More sharing options...
beleive Posted January 27, 2009 Author Report Share Posted January 27, 2009 will took some digging and some learning,but figured it out,it will go to 110 if needed.Run it at 106 its nice. Quote Link to comment Share on other sites More sharing options...
Loren Posted January 21, 2010 Report Share Posted January 21, 2010 will took some digging and some learning,but figured it out,it will go to 110 if needed.Run it at 106 its nice. Please share! I just bought a house that came with a Bullfrog spa. It does get up to 104 as it claims, but I need it about 2 degrees warmer for it to be a pleasant experience. Quote Link to comment Share on other sites More sharing options...
rkp68 Posted June 7, 2019 Report Share Posted June 7, 2019 On 1/26/2009 at 9:39 PM, beleive said: will took some digging and some learning,but figured it out,it will go to 110 if needed.Run it at 106 its nice. Please share!!! Just now trying to increase ours above 104° Quote Link to comment Share on other sites More sharing options...
Dsc Posted February 26, 2022 Report Share Posted February 26, 2022 I can't get my Bullfrog higher the 95 ( even if I set for 104).. The element was recently replaced.. Figure it's the program or temp sensors.. Any thoughts? Thanks.. Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted February 27, 2022 Report Share Posted February 27, 2022 On 2/25/2022 at 7:02 PM, Dsc said: Any thoughts? Yes.. Please start your own post and include photos of the circuit board and the schematic on the inside cover so w know what you have. Quote Link to comment Share on other sites More sharing options...
av8torx Posted January 24, 2023 Report Share Posted January 24, 2023 Has anyone footing how to raise the temperature on a bullfrog spa above 104? A few degrees would be so helpful in the winter when it’s so cold out. Thanks Dave Quote Link to comment Share on other sites More sharing options...
av8torx Posted January 24, 2023 Report Share Posted January 24, 2023 On 1/26/2009 at 9:39 PM, beleive said: will took some digging and some learning,but figured it out,it will go to 110 if needed.Run it at 106 its nice. Hi. Can you please tell me how to increase the temperature above 104. Thanks Dave Quote Link to comment Share on other sites More sharing options...
cranbiz Posted January 24, 2023 Report Share Posted January 24, 2023 3 hours ago, av8torx said: Hi. Can you please tell me how to increase the temperature above 104. Thanks Dave Nope. It's an unsafe hack of the manufacturers set safety limits. Tubs have a maximum set point of 104 as anything higher can cause injuries to those who sit in the tub for long periods of time. 1 Quote Link to comment Share on other sites More sharing options...
av8torx Posted January 24, 2023 Report Share Posted January 24, 2023 I agree 100%. In the winter the outside temperature is sometimes single digits. Having it set to 104 only allows the water temperature to get to maybe 100 with no wind. Normally it drops to 98-99 degrees which is not enjoyable. It would be nice as an owner of my own hot tub to decide what is safe and unsafe for me. If the manufacturer sets limits on their products then they have done their due diligence to protect the consumer. Same goes for a helmet on a motorcycle or a seat belt. Quote Link to comment Share on other sites More sharing options...
cranbiz Posted January 24, 2023 Report Share Posted January 24, 2023 Unfortunately, the world we currently live in, won't relieve the manufacturer of liability should someone get injured because of someone hacking the controls. Ask McDonalds how the "coffee is hot" warning worked out for them. Google is your friend should you wish to pursue this, Bullfrog normally uses Gecko spa packs. Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted January 24, 2023 Report Share Posted January 24, 2023 2 hours ago, av8torx said: Having it set to 104 only allows the water temperature to get to maybe 100 with no wind. @av8torx In the future please start your own post/thread. If this was the case it would be running all the time trying to heat to 104 and cost a small fortune. Perhaps you have a programming issue. There might be 2 different settings you might have on your topside if your spa uses a balboa based system... Range (hi and low) and Ready/Rest modes. Incorrect settings might limit the spa temperature to 99 degrees or only heating the water during filter cycles. Your topside might be different than shown in attached videos but if it is a balboa based system it should have the same settings available. Should always be set for Ready and in the high range setting See the attached videos: https://www.youtube.com/watch?v=8bPLNakHprs https://www.google.com/search?q=bullfrog+spa+ready+rest+mode&rlz=1C1GGRV_enCA752CA753&oq=bullfrog+spa+ready+rest+&aqs=chrome.2.69i57j33i160l2.9213j1j15&sourceid=chrome&ie=UTF-8#fpstate=ive&vld=cid:eae00349,vid:mWmceiW-rFk Quote Link to comment Share on other sites More sharing options...
av8torx Posted January 24, 2023 Report Share Posted January 24, 2023 Thank you for the info. I’ve been to plenty of natural hot springs. Some offer different temperature pools to use based on your comfort levels. I’ve enjoyed springs in the 106 -108 range. It would be nice if we could adjust our personal spa to a temperature of our liking. Any ideas on how I can get my spa above 104? Thanks Dave Quote Link to comment Share on other sites More sharing options...
av8torx Posted January 25, 2023 Report Share Posted January 25, 2023 Unfortunately McDonalds still sells hot coffee with warning labels. I guess they didn’t learn their lesson either! Oh well one day I’ll figure out how to live dangerously Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted January 25, 2023 Report Share Posted January 25, 2023 Living dangerously can come at a cost. Hot tubs have many safety features mandated by the Gov. to protect consumers from themselves and or manufacturers. 104 Temp limits is one of them. I think most of us volunteers on this forum feel a moral obligation to not share bypassing certain mandated regulations. You might be the most competent person in the world and could bypass safety features without issue but these posts are forever and available to a wide audience. Some might not be as competent as you. JMO Quote Link to comment Share on other sites More sharing options...
