southportmom Posted March 9, 2010 Report Posted March 9, 2010 Purchasing a 15x30 pool. I plan to heat it with a propane heater. Any recommendations ? I was thinking of a Sta-rite or Hayward ? Quote
ps558 Posted March 9, 2010 Report Posted March 9, 2010 Purchasing a 15x30 pool. I plan to heat it with a propane heater. Any recommendations ? I was thinking of a Sta-rite or Hayward ? Hayward make a decent heater just not the H100 for above ground pools. I prefer Raypack heaters http://www.raypak.com/poolframe.htm Quote
Gavin Posted March 10, 2010 Report Posted March 10, 2010 I like the look of those Thermal Heat Pumps. Any tried one? Quote
Pool Clown Posted March 10, 2010 Report Posted March 10, 2010 I prefer Raypack heaters http://www.raypak.com/poolframe.htm +1 Quote
Gavin Posted March 10, 2010 Report Posted March 10, 2010 I prefer Raypack heaters http://www.raypak.com/poolframe.htm +1 PC what do you think about AquaCal? Quote
southportmom Posted March 10, 2010 Author Report Posted March 10, 2010 I prefer Raypack heaters http://www.raypak.com/poolframe.htm +1 What size pool heater would you buy ? I was thinking of the Sta-rite 333 or Raypak around 270 Quote
southportmom Posted March 10, 2010 Author Report Posted March 10, 2010 I prefer Raypack heaters http://www.raypak.com/poolframe.htm +1 Also with Raypak, I confused between the digital and the low NOx Quote
Pool Clown Posted March 12, 2010 Report Posted March 12, 2010 Sorry Gavin, Aquacal is a heat pump, and we don't offer them (to our customers), so i can't comment on them. Mom, Even though the pool is only 15 K i would still recommend the largest res. heater, 400K +/-. In terms of time it takes to heat up. That also goes for efficiency too. Raypak claims that it takes less gas to heat with their larger heaters by running less (time). Either one is a good unit. The Sta-Rite is very fuel pressure sensitive. That means that you may need to upgrade your gas meter. If you go Raypak, and you live in southern Calif. you will need to get the Lo Nox version. I have heard that the Texas requirement for Lo Nox is being reviewed. But that could be bad info on my part. I'm sure someone will be along eventually that can clear that part up. Quote
