J27 Posted March 12, 2021 Report Share Posted March 12, 2021 Hi I'm new here , just thinking is the any body can give me advise ? I have beachcomber hot tube and all working a part of is not heat a weather at all , is the any think I can do my self . What could be the worst case scenario Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted March 12, 2021 Report Share Posted March 12, 2021 Not sure I understand. Are there any errors on the controller? Remove filters and try. Quote Link to comment Share on other sites More sharing options...
J27 Posted March 12, 2021 Author Report Share Posted March 12, 2021 No errors , all jets working fine , just cold water , I don't now is this heating pomp or something else , Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted March 13, 2021 Report Share Posted March 13, 2021 Attachment is unavailable. No error codes and no heat is usually a faulty board or heater. Do you have a voltmeter? Check for voltage across the heater terminals on the circuit board. It could be a mode issue. That system should have standard mode (st, std), economy mode (economy, econ), and possibly sleep (sl, slp). Standard allows the system to turn on the pump and heat on demand, economy allows heating only during filter cycles, and sleep turns off the heater. Some heaters will have a built in high limit switch that can be manually reset. Check the heater for small buttons or a rubber circle the size of your finger. Quote Link to comment Share on other sites More sharing options...
J27 Posted March 24, 2021 Author Report Share Posted March 24, 2021 Hi , thank you for your instruction , could you tell , is the possibility to fix the main board or need to be replaced , dose any body could suggest where is the best place to ask , I was call locally fixer and been told it will cost me 750£ plus fit in , I'm sending more photos wit serial number . Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted March 24, 2021 Report Share Posted March 24, 2021 Open the balboa box and take a few good pics of the circuit board and diagram on the box cover. Then one of the whole equipment area. Circuit board relays can be replaced by anyone skilled in electronics soldering. The relays are available online. 6 hours ago, J27 said: will cost me 750£ I have no idea how much that is, I am in the USA. It might be the deal of the year, for all I know.😉 Quote Link to comment Share on other sites More sharing options...
J27 Posted April 26, 2021 Author Report Share Posted April 26, 2021 I was send off my main board to hottube specialist and they check it for me it ok working fine , just wonder how can I check pressure switch I'm attaching photo . Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted April 28, 2021 Report Share Posted April 28, 2021 That is a flow switch, and it should close the connection between the two wires when the button on the metal spring is touching the post. If your flow switch were faulty it should show a "flo" error on the display. Quote Link to comment Share on other sites More sharing options...
J27 Posted May 7, 2021 Author Report Share Posted May 7, 2021 Hi , I just bought new one switch Quote Link to comment Share on other sites More sharing options...
J27 Posted May 7, 2021 Author Report Share Posted May 7, 2021 But still shows Flo and 2:0 am on screen , also I was notice I have slow leak , for some reason I was buy 2inch seals but I can't find 2,5 Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted May 8, 2021 Report Share Posted May 8, 2021 The flow switch has an arrow that indicates direction of water flow. Make sure it is in the right position and not screwed in too far or too little. On 3/24/2021 at 11:48 AM, RDspaguy said: Open the balboa box and take a few good pics of the circuit board and diagram on the box cover. Then one of the whole equipment area. 1 Quote Link to comment Share on other sites More sharing options...
J27 Posted May 11, 2021 Author Report Share Posted May 11, 2021 Yes I was notice this arrows and finally working fine back to life very appreciate for your help . Thank you 1 Quote Link to comment Share on other sites More sharing options...
J27 Posted May 12, 2021 Author Report Share Posted May 12, 2021 Just one more thing . Do I really need all them chemicals for hottube , is the any One good liquid or tablets to buy ? Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted May 12, 2021 Report Share Posted May 12, 2021 Read the sticky thread in the water chemistry section by Nitro on dichlor/bleach. Quote Link to comment Share on other sites More sharing options...
