Jacuzzi Flashing Flo Error
#1
Posted 29 May 2008 - 04:14 PM
#2
Posted 29 May 2008 - 05:55 PM
I don't know to much about jacuzzi controls systems unless it is one with a balboa spa pack. If it has a balboa pack you can unplug the pressure switch plug from the circuit board and put a jumper across the the two pins. Have spa spa call for heat it should close the circuit and heat and not read flo. If it still does this it sounds like a pc board problem
If it is a balboa pack try turning to temp sensor about 1/4 to 1/2 turn in the housing. It might heat higher, this is directly from balboa tech school.
The only other thing I know with jacuzzi if it not a balboa pack and has a connector at the top of the circuit board with a bunch wires going to it, 2 are pressure switch wires and can get loose. try to wiggle the wires and push them in.
Hope this helps
#3
Posted 30 May 2008 - 07:20 AM
Hope this helps
You can do all that or just try cleaning your filters first!
#4
#5
Posted 30 May 2008 - 07:31 AM
Or take them out and see if that resolves your problem, if it does then clean them or replace them.
Part Time
#6
Posted 30 May 2008 - 08:00 AM
After the filter check, if your tub has a circ pump, check that too. We have had quite a few that have had circ pump issues, not moving enough water through setting off the flo message.
Have you used a thermometer to check the actual temp of the tub?
Spa and Sauna Sales and Service center
Clearwater and Great Lakes Spas
Helo and Almost Heaven Saunas
Spa Search certified dealer
APSP Member
CPO
#7
Posted 30 May 2008 - 12:26 PM
I have removed the filters in the past and the problem does occur with them removed. I haven't attempted to jump the connectors or inspect any other connections expect for the wires that connect into the pressure switch.
I have not taken any temperature readings other than what is displayed on the panel.
Two quick questions... What does the temp sensor look like? As for the circ pump, which pump is the circ pump (or both)? I have one pump mounted at the base of the tub underneath the control panel, and another mount on the other side of the heating manifold.
Thanks,
#8
Posted 31 July 2011 - 03:46 PM
<!--quoteo(post=54421:date=May 30 2008, 11:31 AM:name=Roger)--><div class='quotetop'>QUOTE(Roger @ May 30 2008, 11:31 AM) <a href="index.php?act=findpost&pid=54421"><{POST_SNAPBACK}></a></div><div class='quotemain'><!--quotec--><!--quoteo(post=54418:date=May 30 2008, 10:20 AM:name=Stevie)--><div class='quotetop'>QUOTE(Stevie @ May 30 2008, 10:20 AM) <a href="index.php?act=findpost&pid=54418"><{POST_SNAPBACK}></a></div><div class='quotemain'><!--quotec-->You can do all that or just try cleaning your filters first! <img src="http://www.poolspafo...IR#>/laugh.gif" style="vertical-align:middle" emoid="
" border="0" alt="laugh.gif" /><!--QuoteEnd--></div><!--QuoteEEnd-->
I have had the same endless issue of replacing the pressure switch and adjusting to no solution. This is the first time anyone had mentioned that THE PUMP may not be moving enough water to register... although it looks about the same as usual in the tub.
see my "endless" thread ... THANKS!
http://www.poolspaforum.com/forum/index.php?showtopic=31703&pid=139875&st=0&#entry139875
