jsordelet Posted February 15 Report Share Posted February 15 Hello all, The impeller on my balboa pump from a 2021 PDC spa broke off and I am searching for a replacement. I have reached out to the place I bought the spa, the spa manufacturer and the pump manufacturer and none of them have been much help. With a bunch of prodding I got the pump manufacturer (Balboa) to give me the part number for the impeller I need but I am unable to find it online. The part number for the impeller provided by Balboa is: 1212541 Can anyone here point me to a place I can buy this impeller? Quote Link to comment Share on other sites More sharing options...
cranbiz Posted February 15 Report Share Posted February 15 I'm not 100% sure but I believe you need an impeller for a Balboa 3HP pump. Contact Spa Depot, Spa Parts, Hot Tub Outpost or someone like those online dealers. You also might want to try PDCSpaParts. They have a rebuild kit for Balboa 3HP pumps. One of them should be able to help you out. Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted February 15 Report Share Posted February 15 12amp high speed would likely be 4hp. Post pics of wet end and also entire pump. What brand of spa is it out of? Remove the wet end and post photos Quote Link to comment Share on other sites More sharing options...
jsordelet Posted February 15 Author Report Share Posted February 15 Spa brand is PDC. Attached are the pics I have. As you can see from the impeller pics, it appears that the impeller sheared off of its shaft and left the female receiving threaded insert threaded on the motor shaft. At least that is what I see. Correct me if I am wrong. Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted February 15 Report Share Posted February 15 I would replace the seal as well. Post the impeller side view front view. Also pic of the front face plate. Odd unit with 3 caps Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted February 15 Report Share Posted February 15 Where are you located? NA, Europe, AU, NZ? Quote Link to comment Share on other sites More sharing options...
jsordelet Posted February 15 Author Report Share Posted February 15 I do plan on replacing the seals as well. I agree that it is odd as I have had zero luck in even finding this exact unit anywhere online which is probably why I am having trouble finding which replacement impeller I need. I will get additional pics of the impeller and the front face plate as soon as I am able. If I could find a replacement wet end that is compatible, I would go that route vs. just trying to find the right impeller. 1 Quote Link to comment Share on other sites More sharing options...
