Brayden Smith Posted February 1 Report Share Posted February 1 I’ve had this hot tub (a Dreammaker Big EZ) for a couple years now, but it’s a bit older than that. It uses ann RS101 balboa system. Everything is working fine still, but the tub won’t heat at all now. When the temperature is set, the heat light comes on, but the temperature won’t rise. After some troubleshooting, I purchased a new heater. Even with the new heater, it still won’t heat. I’m thinking it may be a bad relay on the circuit board, but I don’t know for sure. Any recommendations? I’ve attached a few pictures of the circuit board. There’s one spot that looks like it could be slightly burnt on the back. It lines up with one of the mounts that holds a fuse (the white one towards the right side of you’re looking at the front of the board). I replaced that fuse, but it didn’t change anything. Quote Link to comment Share on other sites More sharing options...
cranbiz Posted February 2 Report Share Posted February 2 Post up the wiring diagram which is usually on the back side of the cover. I suspect a relay has failed but without the diagram, I can't tell which one you should be checking. Quote Link to comment Share on other sites More sharing options...
Brayden Smith Posted February 2 Author Report Share Posted February 2 Here’s the diagram. From researching online, that’s what I assumed as well. Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted February 2 Report Share Posted February 2 4 hours ago, cranbiz said: Post up the wiring diagram Interested to see why the incoming power wires are connected directly to the board like that. Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted February 2 Report Share Posted February 2 OP.. Did it come wired like that? Quote Link to comment Share on other sites More sharing options...
Brayden Smith Posted February 3 Author Report Share Posted February 3 Here’s the diagram. From researching online, that’s what I assumed as well. Quote Link to comment Share on other sites More sharing options...
cranbiz Posted February 6 Report Share Posted February 6 Relay's K3 and K6 are the most likely suspects. Quote Link to comment Share on other sites More sharing options...
