New hot tub owner, model? How to drain?
tdg
Recently moved in and we are trying to figure out what we have going with this hot tub. Any ideas as to model? Has "Jacuzzi" on all the pads. Looks like the prior owners converted it to a Saltron Mini system. We would like to drain it, clean it, etc., but we don't know where to start. Thanks for any info.
Buy a "Quick Drain" See below... Also buy a plumbing line cleaner to do a deep cleaning/purge of the plumbing lines to remove any bio film left behind by the previous owner. I use Ahh-Some line cleaner. Visit the Ahh-Some Web site for how to use directions. The quick drain will drain the spa in about 20 mins and you don't need any electrical to use. It can also be used as a vacuum to pick up debris off the floor and seats like you have in the first photo. The spa is not a jacuzzi just the pillows
https://www.manualslib.com/manual/1724082/United-Spa-Controls-C5-Series.html?page=9#manual
https://www.youtube.com/watch?v=rrKqC4CIxTI
  • No real identifiers of the manufacturer on the cabinet/shell.  However it is an average mid-grade spa using industry-standard components
  • It uses a Balboa C5 Spa Pack - likely an upgrade/replacement.  Balboa is one of the two largest manufacturers of generic spa parts used by dozens of spa manufacturers around the world.
  • Don't stress about the exact make/model - the owner's manuals for these tubs are basically useless and contain very little information. Mainly the buttons on the controller, which knobs control what jets in the spa, and dozens of pages of warnings and legal mumbo jumbo.  There is basically no info about care/maintenance etc.
  • Salt systems can be fun but I'm personally not a fan of them as the water needs to be balanced specifically for the system to generate adequate chlorine, it also makes people lazy assuming it's working even when it might not be working.
I'd also personally grab some AhhSome and a replacement filter for the spa.  Purge the hell out of that spa to eliminate biofilm from the plumbing, then replace the filter to get rid of the "ick factor" of owning a used hot tub haha.
